Recently, I bought and built my first gaming PC. I completed the build a few weeks ago and installed Windows over winter break however I had to use my mom's wireless adapter because I didn't have anyway to connect to the internet. While using wireless, I was averaging around 1-1.3mbps downloads. Since I decided I was going to build the computer, I planned to use a wired connection instead of wireless since it would help reduce lag. I thought I had an ethernet jack in my room however I later found out it was a phone port and I couldn't use it. I was wondering if it was possible to convert the phone jack to an Ethernet jack. From my understanding, it is possible if a Cat-5e cable is in the jack. Is this true? I haven't removed the plating because it's in a hard spot to get to. My house is around 13 years old if that matters. Is this a good tutorial for converting it, if not can you link to one? From my understanding also, I would need to buy something like this and this. Is that correct? How easy would this be for a fifteen year old to do? If it turns out it doesn't have a Cat-5e cable, how can I get one?
All help is greatly appreciated!
