Converting Mp3 to WAV: Possible?
Mork
547
In winamp, go to properties under "output"
and select "wave out"
(or was it "disk writer"? )
notfred
38,241
4
in winamp:
options > preferences > plugins > output > Nullsoft Disk writer > configure - pick a directory.
Close options, hit play. Whyen the playlsit is done, you'l have a lot of wav files. Make sure to switch back to wav out after you're done with the disk writer.
Hyperblaze
10,027
There was this program a while back which I used to use called mp32wav.
Don't use it anymore though...when i burn mp3s to cd...they automaitcally convert to wav if i specify audio
johnjohn320
7,572
<< in winamp:
What file type should I choose when I hit configure? (PCM is default, WAV isn' listed).
edit nevermind, figured it out.
Thanks guys!
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Also, LAME offers the ability to decode MP3 to WAV. Some people think that LAME does a better decoding job than Winamp, but I don't notice much difference.
ZV
GagHalfrunt
25,284
1,998
The best tool for converting .mp3 to .wav or .wav to .mp3 is dBpowerAMP It's freeware, fast, great output quality, does batch edits and integrates into the system shell so conversions are a simple matter of right clicking an audio file and choosing "convert to..."
