Gamingphreek
My computer is in my bed room. As a result it gets pretty hot in there. I know that since it is still using power it will still produce heat. However, if i go to watercooling, will that significantly cool down my room, as i dont have hot air circulating around.
I was considering the Zalman Reserator since it is cheap, and it is completely silent. Does anyone know if the Reserator (i assume it will, but since it is fanless im not 100% sure) will cool better than a 7700Alcu or XP series.
-Kevin
-Kevin
