SpicyCurry
Guest
Hi, I'm a newbie to water cooling, and I was wondering whether it's possible to have a loop only for the GPU. Ordinarily, I would think that if you can do a CPU only water loop, there's no reason you couldn't do a GPU only loop. I did a quick search on this forum to see if anyone has mentioned GPU only cooling, and I couldn't find anything. So at the risk of sounding stupid, is it possible to only cool the GPU?
The reason I want to skip the CPU loop is because I already have an aftermarket fan on my CPU. I'm very happy with the performance of this fan, so I'd rather not replace it with a CPU water block if I can help it.
I currently have an GTX260 216, using an HAF 932 case. I don't plan on watercooling my current GPU, but maybe for my next video card when I upgrade.
