Considering a used Porsche Purchase
JackBurton
15,993
14
This. My back seat is for packages, not people. Except my little nephew, he fits back there. An adult? Not unless it's Peter Dinklage.
If I were looking for a Porsche, in the $40k range, I'd be all over a Cayman. Like this: http://cargur.us/dxct
IMO, to get to 40k in a 911 you're going to need to make sacrifices, big ones. Either in mileage or age, and neither is very kind to that platform. Compared to the Cayman; repairs are more, service is more, and performance is less (since you have to go so far back).
Get a Cayman (or Cockster) with as few miles as possible, then keep a tight service regemine. Don't use it as a weekend-only driver, drive it often and don't baby it. Mind those things and it'll serve you well for a long time.
Why isn't it a good idea to use a Porsche as a weekend car?
Fenixgoon
33,421
13,044
i was once looking at a ~2006 +- 1yr Cayman S. thought it would be an excellent DD/autocrosser. sadly my money is not of infinite supply :(
and i know maintenance isn't cheap on porsches.
hans007
20,212
18
One thing with older Porsches is the ims bearing issue. Seems to affect 5-10% of pre 2009 I think Porsches.
When it fails it takes your engine with it apparently. Friend of mine almost bought a boxster and got an s2000 instead due to that. 911s have it too
You cab buy some sort of retrofit kit that makes it not fail I think.
manimal
13,559
8
ya as mentioned way too many times on the internet the intermediate shaft can fail catastrophically. The retrofit kit costs about 600 bucks though a cheap version is in the works according to pelican parts. I really wouldnt worry about a failure. I have seen only one and actually inspected the engine since it was somewhat a novelty.
If you buy a used Porsche replace the IMS when you do the rear main seal and the clutch. Boom your good to go.
I know three shops here in indy that would do that job entire job for under 3k. Thats including a new clutch.
Imdmn04
2,566
You can get a nicely optioned 50K mile 996 Turbo for mid $40Ks; no contest between a cayman, 997 or a 991.
I ended up taking the back seats out entirely; at least it's somewhat useful as cargo room.
A Cayman with a rear mid-engine layout is much more balanced than the antiquated 911 with the rear engine layout.
Most of the Porsche enthusiasts have long expressed that Cayman has a technological superior platform. The only reason that Porsche hasn't put in a higher HP engine in it is that they are afraid of it stealing 911 sales.
Plus from an affordability standpoint, maintenance on a 10 year old 911Turbo will hurt the pocket much more than a 3 year old Cayman for someone whose budget-conscious (he must be because he is buying a used-Porsche)
RichieZ
6,551
40
Back seat on my 911 is pretty much useless; you will not be happy with the car in that regard. They're really 2 seaters.
They do have a weak spot in the so-called intermediate shaft, 99-09 cars have a set up that relies on a bearing to distribute the timing from crank to the cams and it's prone to failure. Luckily there's an aftermarket fix available for ~$600 + labor for pre-06 cars that adds great deal of reliability. The failure rate of 06-09 cars are minimal (latest bearing design).
Also maintenance isn't cheap, especially at he dealer.
Interior on the pre-05 cars is a function of the options the car came with; my 4s has full leather, body matched console, stitched airbag, wood inlays etc etc. The base cars are pretty meh-looking though.
so did you do the LN engineering IMS bearing retrofit on your 996?
GoatMonkey
1,253
I've had brief daydreams of getting a 911. Enough that I read some owner reviews on used car sites like Edmunds. I don't think my pockets are deep enough even for the standard maintenance. Also, there were a few posts that I read where the owners had major engine failures. It's about $23K for a new engine on a non-turbo 911. Think about a warranty just in case for major stuff. The numbers on that were relatively small though. Out of about 200 reviews on one site there were 3 or 4 that had engine failures. That's really not that bad when you think about it. The people most likely to write a review are the ones with a terrible experience. And some of them were just stupid, who buys a used Porsche with 90k miles and expects it to be perfect?
deadken
3,199
Back in the late 1980's (and again in the early 1990's) I used to work at a European Auto repair shop. There was a saying there:
You don't save up to buy a Porsche. If you have to save to buy it, you'll never be able to afford everything else you need for it (maintenance, insurance, repairs, etc...).
Good luck with whatever you choose.
MagickMan
7,460
Because they actually age/wear better if driven regularly. It's an everyday sports car, built to be driven every day. As I mentioned before, my Carrera S is my DD and it does it perfectly (and makes regular trips around town a lot more fun).
manimal
13,559
8
while your technically right one could get away with it like I did for a long time. In the summers I would take it one day a week as a reward to myself.
tongqi2
24
Maintenance isn't really that bad on 911s. If you don't track, you won't go through tires/brakes like crazy either.
halik
25,696
I don't disagree, the layout should make for a far better balanced car. In all honesty I wouldn't be opposed to buying one, the 911 is just slightly better all around choice (AWD, more space with the fake-back seats, better options etc... also my car looks better imo).
The maintenance should actually be fairly identical; turbo cars have very little weak spots (spoiler rams ?) and the labor runs about the same.
RichieZ
6,551
40
996 looks better than the cayman? you are probably in the minority, but glad you enjoy it
Throckmorton
16,829
I would think a 911 is easier to repair because the engine is accessible from above, instead of only from below
halik
25,696
Widebody 996, absolutely. I don't find cayman all that well proportioned, especially from the rear.
151661d1282179201-porsche-996-turbo-47k-6spd-clean-low-miles-upgrades-dsc_0457-medium-.jpg
manimal
13,559
8
im gonna go all in and say I would rather have Haliks 911 too ^^
and I am a guy who LOVES caymans
Blieb
3,475
Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual Manual
Phanuel
2,304
doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe doppelkupplungsgetriebe
