ShintaiDK
- Apr 22, 2012
- 20,378
- 145
- 106
I have a feeling that Skylake is very far away, heck we don't even know what clock speeds are going to be offered
We do and its close.
http://forums.anandtech.com/showthread.php?t=2428363
Why full size PSU? You can get 600w SFX PSUs which is enough for any card+CPU you would want in a smaller case. Even 450w is enough for a non-overclocked HD4460 and HD7950.
So I can get a bronze, silver, platinum or gold certified power supply by a reliable manufacturer like Seasonic. I like a 500 watt PSU even if my system would use 250 watts max because I find they stay cool like that.
Additionally, what mini-ITX cases would you guys recommend? I don't mind paying well for quality but would really like something small and well-built.
The Elite 110 is cheap but I found the power supply placement to be obnoxious enough that I quit using them in builds. There are smaller cases with better layouts for very little more.
What length ATX PSU were you using? (140mm is the standard length, but they can be found 160mm or longer)
And what do you not like about the PSU placement?
It was slightly longer than standard ATX, and was rather annoying when used in combination with an aftermarket cooler. I want to say I think the last build I used that case in was a Haswell i5 with a Big Typhoon (which my brother already owned), which technically fit but was a nightmare to install. I've since moved to cases and coolers that don't obscure motherboards from above with my ITX builds, as I don't like having to half disassemble it to add a hard drive or reset the CMOS.
EDIT: Considering the dead-space in the front, it just wasn't worth it.
I find 120mm fans are more silent. If you look at the SeaSonic M12II 520 (modular PSU), it has a 120mm fan.
(I currently have a SeaSonic S12II.)
The first time I looked at mini ITX, there weren't many models that took a full-sized PSU and the selection of coolers was also bleak. Now, there's more flexibility except I didn't find motherboards with the same kind of audio (Realtek ALC 1150) as I have now. If I could find a mini-ITX case that takes a reasonably-sized video card, full-size PSU and a good heatpipe cooler for the CPU and a motherboard with real high definition sound, I'd go for it.
