Connecting two thin wires
Elstupido
643
Problem with stripping wire that small is it is very easy to damage the conductor by nicking it even ever so slightly. A nicked conductor like that, will lose strands, or if solid, break easily.
Howard
47,982
11
You could always torch the insulation.
alphatarget1
5,710
I found some at Home Depot for 22 AWG. Do you think I can still clamp it down if my wire is thinner?
waitman
3,758
Originally posted by: TallBill
Strip the ends and get one of those plastic things that twists them together inside. Cant think of the name.
Wire nuts?
0roo0roo
64,795
84
.... the connection won't be as secure. connectors tend to have a range of sizes that it can fit, it will say on the back. like 12-16awg or whatever.
radioshack/homedepot/lowes/frys all have plenty of options. heatshrink is nicer than tape though.
wirenuts are only good for thicker wires.
as for nicking wires. basically you make the nicked spot thinner, so effectively its higher gauge bit at that point which can lead to overload/failure point.
and you can always hotglue/ziptie for extra reinforcement to take strain off the connector.
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
Search for "Scotch-Lok" crimp-on connectors.
They're button size, and you don't need to strip the wires.
I believe I've seen them at Home Depot.
Good Luck
