- Dec 9, 2001
- 5,710
- 0
- 76
I'm trying to find an easy way to connect 2 24-26 AWG wires together without soldering. Anyone know of good connectors (insulated) I can use?
Originally posted by: Howard
Marrette, but I'd still like to know.
Originally posted by: TallBill
Strip the ends and get one of those plastic things that twists them together inside. Cant think of the name.
Originally posted by: haffey
Strip the plastic, twist the wires together, and throw some electrical tape on it.
I like crimp-on connectors if you aren't going to disconnect the wires.Originally posted by: alphatarget1
solid or stranded?
stranded
Originally posted by: silverpig
Youre wires are too short. Get a longer piece of wire.
solid or stranded?
stranded
A male and a female quick disconnect terminal. For 24-26AWG you'll probably want 0.110" tabs. Or you can try twist-on butt splices but I've never used those before.Originally posted by: alphatarget1
solid or stranded?
stranded
I need to disconnect the wires.
solid or stranded?
stranded
wire nut?
Home Depot will have them, but try a local industrial supply store that deals in electrical/electronic products.Originally posted by: alphatarget1
solid or stranded?
stranded
I think that may work... Thanks! Do you know where I can get them?
