azazel1024
The router will also connect the wireless devices to the network and act as a DNLA server for all connected devices.
Doesn't change my recommendation on how to structure things.
On a consumer grade router it probably doesn't matter one way or the other. On better routers where each interface is a full blown interface and not just a switch it would be better to connect switch A to switch B. Best to keep LAN traffic on switches and not have to be processed through a router. Traffic should only hit a router if it is going from one subnet to another.
Very true, but it sounds like there will be limited to no traffic between the other devices on the network. Its all going to be from/to the router, so it would make sense to make the router the central point with the two switches off of it.
It would make better sense to have a real NAS attached to one of the switches, make that the core and dangle the router and other switch off it, but OP wants to use the router as a NAS.
You think if 3 people are watching an HD video on their devices or TV, and a 4th device tries to access a video, could this cause problems?
What if two devices want to open the same media file? Could this cause a problem.
