Confused on what Wireless PC Card Standard to use for SMC Wireless Router
AnimEva
3,298
I have a SMC Barricade Turbo 11/22Mbps Router Model SMC2404WBR.
I want to use the 22 Mbps for it. What type of Wireless card do I need to get it to be 22Mbps?
Sorry, I am pretty confused on how wireless standards work, any help is appreciated. Thank you.
JackMDS
29,538
418
The standard is 802.11b. It is capable of 11Mb/sec.
Few manufactures use a ?Trick? to squeeze 22Mb/sec.
It is still compatible with the regular any 11Mb/sec.
If you buy a 22Mb/sec. capable Client card it will do both.
Be aware the theoretical 11Mb/sec. usually yield working 4-6Mb/sec.
The 22Mb/sec. card will add about 20-30% more.
A good 11Mb/sec. Wireless card might perform better than a so so 22Mb/sec. card.
General Info here: Wireless What Should I Get (Early April, 2003 Edition)?
