Ok good news and bad news. Good news is that I found a workig PSU that confirms that it works, bad enws is that this PSU dont ahve the 4 pin 12 V thing so i cant use it with this mobo, unless you know of soething i can do....
You can buy an adapter that converts a standard drive plug to an ATX12V plug, but my advice is to go get a new high-quality power supply. Anything that's so old it doesn't have an ATX12V plug... 😛
I might do that, because since i fricked up my other PSU by sleeving it, Ill just buy a presleeved one, the only thing is that i need it very soon, so i dont know if itll get here by then.
