- Jan 6, 2002
- 23,121
- 1,274
- 126
Here is my specs
XP 1800+
MSI Nforce2 MB
Gforce 4 440MX
512 megs Kingston DDR 333
this system is a few months old. As of yesterday I started to have this problem. The monitor will randomly click off, like when they go into power saving mode. I have that disabled. The actually PC doesn't beep, it doesn't reboot, and it doesn't shut down. I am thinking it must be something with my PSU. It's a ummmm "Powerup" I believe 350 watts. I know it's not the best brand, but I've had good luck with them in the past. I don't think it's a over heat issue. Because I can play SOFII with no problems. The problem can happen when the system is basically idle.
Besides PSU, does anyone have a suggestion what else it could be?
Windows isn't beeping, I get no BSOD, and aside from the monitor "clicking" nothing else seems to be happening wrong.
very confused here
XP 1800+
MSI Nforce2 MB
Gforce 4 440MX
very confused here
