Originally posted by: Accipiter22
Originally posted by: dclive
OP: Please completely disable system restore on all drives. Does anything change?
Please run mpsreports, send me the .cab output file, and give me all the dumps you've got.
I never had system restore on
Interesting, because the DLL that System Restore depends on is what the debugger is pointing the finger to - and not just once, but every single time. See results below.
Interestingly, the debugger also said that the buffer overrun is a common hack exploit. Seems unlikely, but then I looked and it turns out it appears your PC is directly on the public internet, without a router in between to protect you (is that possible?! Does anyone still actually do something that dangerous?!) Your IP, 71.192.x.x, appears to be a public address on the public internet. Get a NATting router and put it between your PC and your internet connection.
But then I saw that your system event log has dozens (no, hundreds) of chkdsk disk errors. Run chkdsk on your two systems, set to fix, and see if you can get your disks to come up clean. Run it until it comes back completely clean. It's hitting both C: and D:, per the errors:
6/25/2006 7:36:31 PM 1 2 55 Ntfs N/A x The file system structure on the disk is corrupt and unusable. Please run the chkdsk utility on the volume D:.
(repeated plenty of times)
and
6/27/2006 9:34:53 PM 4 0 26 Application Popup N/A x wmp10.exe - Corrupt File The file or directory C:\DOCUME~1\x\LOCALS~1\Temp\IXP000.TMP is corrupt and unreadable. Please run the Chkdsk utility.
...repeated hundreds of times in slightly different ways.
..but then I went to your Application logs, where I saw you *are* running chkdsk (why didn't you mention this!?) and you're getting all kinds of errors:
6/27/2006 10:07:06 PM 4 0 1001 Winlogon N/A ACCIPITERII Checking file system on D: The type of the file system is NTFS. One of your disks needs to be checked for consistency. You may cancel the disk check, but it is strongly recommended that you continue. Windows will now check the disk. Cleaning up 3 unused index entries from index $SII of file 0x9. Cleaning up 3 unused index entries from index $SDH of file 0x9. Cleaning up 3 unused security descriptors. 218596454 KB total disk space. 14976856 KB in 15267 files. 4996 KB in 948 indexes. 0 KB in bad sectors. 89410 KB in use by the system. 65536 KB occupied by the log file. 203525192 KB available on disk. 4096 bytes in each allocation unit. 54649113 total allocation units on disk. 50881298 allocation units available on disk. Internal Info: 70 3f 00 00 62 3f 00 00 9a 58 00 00 00 00 00 00 p?..b?...X...... 29 02 00 00 00 00 00 00 32 00 00 00 00 00 00 00 ).......2....... 1e 85 66 00 00 00 00 00 04 d6 39 0a 00 00 00 00 ..f.......9..... 20 bc be 00 00 00 00 00 00 00 00 00 00 00 00 00 ............... 00 00 00 00 00 00 00 00 a2 ff 5f 12 00 00 00 00 .........._..... 99 9e 36 00 00 00 00 00 80 39 07 00 a3 3b 00 00 ..6......9...;.. 00 00 00 00 00 60 1d 92 03 00 00 00 b4 03 00 00 .....`..........
You're getting this constantly - again and again and again and again.
I suggest you check your entire disk subsystem.
Debug output:
Microsoft (R) Windows Debugger Version 6.6.0003.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Documents and Settings\....\desktop\....\Mini062706-02.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*x:\websymbols*
http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 2600.xpsp_sp2_rtm.040803-2158
Kernel base = 0x804d7000 PsLoadedModuleList = 0x805531a0
Debug session time: Tue Jun 27 19:46:46.390 2006 (GMT-5)
System Uptime: 0 days 0:00:42.968
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck F7, {12, 3ef3, ffffc10c, 0}
Probably caused by : sr.sys ( sr!SrGetAclInformation+12a )
Followup: MachineOwner
DRIVER_OVERRAN_STACK_BUFFER (f7)
A driver has overrun a stack-based buffer. This overrun could potentially
allow a malicious user to gain control of this machine.
DESCRIPTION
A driver overran a stack-based buffer (or local variable) in a way that would
have overwritten the function's return address and jumped back to an arbitrary
address when the function returned. This is the classic "buffer overrun"
hacking attack and the system has been brought down to prevent a malicious user
from gaining complete control of it.
Do a kb to get a stack backtrace -- the last routine on the stack before the
buffer overrun handlers and bugcheck call is the one that overran its local
variable(s).
Arguments:
Arg1: 00000012, Actual security check cookie from the stack
Arg2: 00003ef3, Expected security check cookie
Arg3: ffffc10c, Complement of the expected security check cookie
Arg4: 00000000, zero
Debugging Details:
FAULTING_IP:
f73f1744 e8ce22ffff call sr!_SEH_epilog (f73e3a17)
GSFAILURE_FUNCTION: sr!SrGetAclInformation
GSFAILURE_MODULE_COOKIE: <unavailable> sr!__security_cookie [ f73e538c ]
GSFAILURE_CORRUPTED_COOKIE: 00000012 [ ef955a48 ]
GSFAILURE_ANALYSIS_TEXT: !gs output:
Stack buffer overrun analysis follows:
Corruption occured in sr!SrGetAclInformation or one of its callers
Error reading real canary at 0xf73e538c
Error reading real canary complement at 0x00000000
GS analysis will be limited due to previous errors
Corrupted canary at 0xef955a48: 0x00000012
Corrupted cookie value (0x00000012) too generic, skipping read bit-flip check
EBP/ESP check skipped: No saved EBP in exception context
Function sr!SrGetAclInformation:
Funtion has no locals
no candidate buffer found
Stack buffer overrun analysis complete.
SECURITY_COOKIE: Expected 00003ef3 found 00000012
CUSTOMER_CRASH_COUNT: 2
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xF7
LAST_CONTROL_TRANSFER: from f73e39ad to 804f8925
STACK_TEXT:
ef955990 f73e39ad 000000f7 00000012 00003ef3 nt!KeBugCheckEx+0x1b
ef9559b0 f73f1744 85cb9828 85d66e88 00000000 sr!__report_gsfailure+0x25
ef955a64 001f01ff 00000501 05000000 00000015 sr!SrGetAclInformation+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
ef955b04 f73eef22 ef955bf0 f73e3a2e f73e3e20 0x1f01ff
ef955a7c 320a1743 000003eb 3bab58ea 01c694dd sr!SrUpdateBytesWritten+0x8a
ef955b04 f73eef22 ef955bf0 f73e3a2e f73e3e20 0x320a1743
STACK_COMMAND: kb
FOLLOWUP_IP:
FAULTING_SOURCE_CODE:
SYMBOL_STACK_INDEX: 2
FOLLOWUP_NAME: MachineOwner
SYMBOL_NAME: sr!SrGetAclInformation+12a
MODULE_NAME: sr
IMAGE_NAME: sr.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 41107cde
FAILURE_BUCKET_ID: 0xF7_sr!SrGetAclInformation+12a
