update... well this is what i tried... i clear the cmos, and then i boot the computer... surprisingly it posts... but, it doesnt run through the ide check or proc/mem check. no award bios or whatever.
first it shows a screen with the asus a8v mobo. then it goes into something about the cmos error or whatever, cant remember the exact words. it gives me two choices. one, F1 to go to setup, F2 to load defaults. i tried both. when i push f1, it takes me to the bios screen. so i set my date and time and exit. do i need to do anything else at this point? in the bios, i also checked up on the cpu and mobo temp. it read about 30 degrees cel for the processor. so i figure, hmm if thats very close to accurate, then the processor is fine right? the case temp read about 20 degrees or so. so then i save and exit, and it tries to restart, but doesnt post anymore. it just showed a blank screen like before. i tried to restart and doesnt work. then i cleared cmos again, and this time i selected F2 to load defaults, and then right away it gave me a blank screen again. asdflkja;lksd. ok so what other alternative do i have now? should i flash the bios somehow? and if yes how do i do it? i mean i dled that bios 1008 update and did as you said about renaming it to .ROM. but when i stick it in there, and try to make it read, it says data invalid or something along those lines. please help.
