Computer Part list check
buck
12,273
4
Originally posted by: bamacre
:laugh:
Man, if you don't want to listen, fine, stick with the 7600 GT. :roll:
This will give you twice the gaming performance than that...
Antec Performance TX TX1050B SOHO Mid Tower case (Black) Retail
$125.98
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=140119
Asus P5ND2-SLI nForce4 SLI Intel Edition P4/Pentium D/Celeron 1066FSB LGA775 DDR2 ATX Motherboard
$92.99
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=247012
Intel® Pentium® D Processor 940 3.2GHz, 800MHz FSB, Socket 775, 2x2MB Cache, Dual Core Retail
$243.80
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80852
Corsair VS2GBKIT667D2 2GB Kit DDR2-667 PC2-5300 Value Select Memory Retail
$145.90
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=85016-47
Seagate Barracuda 7200.9 ST3300622AS 300GB Serial ATA 7200RPM Hard Drive w/16MB Buffer
$115.00
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=101543
NEC 16X DVD±R DVD Burner Black IDE/ATAPI Model ND-3550A
$40.95
http://www.newegg.com/Product/Product.asp?Item=N82E16827152058
SAPPHIRE Radeon X1900XT 100149SR Video Card - Retail
$406.66
http://www.newegg.com/Product/Product.asp?Item=N82E16814102004
Total Price Shipped: $1,171.28
Literally, TWICE the gaming performance. Not to mention, 2GB of ram, and double the HD space, and faster hd as well.
The best advice you will get....
Howard
47,986
11
Originally posted by: kidcool321
VideoCard - http://www.newegg.com/Product/Product.asp?Item=N82E16814102003 389.99
That's $10 more but has a $30 mail-in rebate.
The same PSU goes for $84 + shipping here:
http://www.case-mod.com/store/seasonic-...-pcie-power-supply-sleeved-p-1891.html
Or you can go for the Fortron FSP400-60GLN which is slightly louder but just as powerful.
EDIT: The case-mod link should be:
at the end of it, add "?src=fr" to get the sale price.
For 55 cents more, you can get the Samsung SP2504C 250GB SATA-II which is much quieter and probably performs better.
tjpark1111
287
adding shipping makes it more expensive than newegg for me. just get it from ZZF when they're back in stock, $90 free 2 day fedex.
alimoalem
4,025
this and your previous parts list (posted a couple posts up) look excellent. howard's recommendation on the cheaper video card is a good change though.
i think your parts list is totally better than fx's. his video card listed is a LOT weaker and the ram is not only more expensive, it's slower too.
just wondering, how old are you? and do you have a pretty high income (no need to know the amount, just a yes/no answer). the reason i ask is DX10 cards come out either end of this year or beginning of next year (i forgot which) and those are supposed to be real powerful. if you are able to save up a bit of money by then, getting the x1900xt is a good idea. if you're not going to have too much disposable money in 6 months, maybe getting a 7900GT for ~$250 is a better idea so you'll have $150 saved up and you'll probably be able to sell the 7900GT for at least $175, leaving you with just $75 needed to be saved over a 6 month period to get a DX10 card. (DX stands for Direct X). just a thought.
but definitely go with your current configuration over the other suggested ones.
alimoalem
4,025
Originally posted by: GeeFizzleDizzle
I love it when someone's available money outweighs that person's available braincells.
is this the case for u? cause it doesn't seem to be so for the OP
