Muse
- Jul 11, 2001
- 40,434
- 9,941
- 136
No brainer. When on, my computer uses around 140 watts. If I'm using my CRT, closer to 200 watts. When you shut it off, it uses either no watts or maybe 5 depending on whether or not it's plugged in. Myself, I always turn off the main power strip when I turn off my computer equipment. This drops power consumption to zero and has no negative consequences. The computer has an internal battery. Turning on your computer doesn't consume more than anything else. Keep it off when not using it for any reasonable length of time (say, an hour) and you will save money.Originally posted by: plastick
okay i hope this is the right friggin forum for this..
I was wondering if the average computer consumes more electricity when left on all the time as apposed to when its being turned on and off after its done being used.
Im asking because Im moving to an apartment where i have to pay for my electricity so i want the bill to be cheap. Plus its good common knowledge..
I have an athlon 64 bit cpu vnf3 mobo with a gforce 4 video card and i usually use it for internet and word processing and photoshopping and play games like starcraft (So thats what i demand from my pc).
any info?
I keep some of my components on power strips that are plugged into my main power strip (which is a fancy surge protector). Components that I only use occasionally are plugged into one of these auxiliary power strips, which are generally off. On those are things like my printer, my external modem, my scanner, most of which have wall warts, which continually draw power even when the units plugged into them are off. I save around 25 watts right there even when computing.
