stevty2889
Have you tried botting up with the hard drive unpluged from both the PSU and motherboard?
Originally posted by: cecco
I just tried putting a win 98 boot disk in the floppy (WinXP PRO installed in hard drive) and continues to some sort of setup screen that I have never seen before with three choices:
Reinstall win 98 without reformatting
Install win 98 with format
exit
Several questions here. If I continue install and insert the XP pro CD instead will it work? More importantly will the applications currently installed work again.
If I were to swap the hard drive in question with the good one from my own comp, is there a chance that it too could become corrupt?
Yes, you are right about the warranty. Reason I said that was because the slip I found said limited 1 year warranty, however upon checking the serial number on their website I found that It was still under warranty.
I didn't build the PC, however It had been running for over a year with no problems, again the hard drive failed even when placed on a different computer.
Googer, that was my mistake, the OS on this system is actually win 98SE. It had been a while since I saw this computer with it's operating system up and running and my friend had a windows xp disk that he wanted to install from scratch. Well I guess he'll get the chance now.
I hope I never see this error message again! But thanks again for your help.
What would you recommend? Computer will be used by the owner of a small business in order to run quickbooks and use the internet, reliability a must.
