- Sep 13, 2003
- 93
- 0
- 0
Hello, I need serious help on create this P4 PC. . . Below are the specs that I am planning to buy:
Intel Pentium 4 / 2.4GHz 512k socket 478 Hyper Threading Technology 800 MHz
Intel® Desktop Board D865PERL
512MB PC3200 (3-3-3),400MHz DDR NonECC CL3,KVR400X64C3A/512
GeForce FX 5600 256MB DDR Video Card & DVI Geforce FX5600 256MB DDR
WD400BB 40.0gb EIDE 3.5 LP 7200rpm
HP F70 17" LCD, Integrated Polk Audio Speakers, Refurbished
Intel 10/100 LAN CARD
Logitech Z-540 40 Watt 5-Piece 4.1 Surround Sound PC Speakers
Artec CDRW 52x24x52x
CD-RW & DVD COMBO 8X/4X/32X/8X SM308 Beige
http://support.intel.com/support/motherboards/desktop/D865PERL/rl_matrix.htm is the link to the motherboard. . .
Now, my questions are:
The Nvidia FX 5600 . . . will this be compatible with the mobo even though it already has graphics? Is there a way to disable the mobo installed graphics in BIOS or something?
Also I am planning to buy a Sound Blaster Audio Live sound card, and the mobo already has audio in it, . . . and like the vid card, is there anyway I can disable it?
Plus, what kind of case should I get, in terms of Power Supply? 400 should do?
Thanks alot for your help guys
