Merry xmas.
I received a Celery M 370 1.5 ghz laptop for xmas but want to swap it for an AMD laptop and in the process, I will replace my desktop PC. Need advice.
Ok, my rig is this:
AMD64 3000+ (Artic Silver + oem HSF)
MSI Neo2 Platinum
XP Pro SP2 (not sure if I could/should keep this)
1GB OCZ Premier DDR 2x512M PC3200 (2.7V 1T 2.5-3-3-10)
Geforce2 GTS AGP card (I know...I don't play games..if I change my mind I upgrade)
Seagate 7200.7 200 GB SATA HD
EIDE LG 4163B DVD burner (may keep burner)
less important specifics
CASE: Enermax CS-656-TA ATX case w/ 3 fans
(2 front USB, 2 audio (mic/line) & one firewire port. Adjustable fan control and temp readout.)
PSU: Enermax EG425P-VE SFMA PSU (12V=29a)
PCI cards: Haupaugge PCI PVR 250 video capture card/TV tuner (I lose this..but outboard USB tv tuner capture with a laptop is ok too)
Monitor: Samsung 712N 17" LCD monitor (specs - 600:1 contrast and 12ms) & 3 year warranty (may keep this, or, if 15.4" widescreen is ok, I will sell it too with above)
Comparing this Gateway Turion64:
http://www.bestbuy.ca/catalog/proddetai...S10069888&catid=20354&logon=&langid=EN
vs this Compaq AMD64 3500:
http://www.bestbuy.ca/catalog/proddetai...N&sku_id=0926INGFS10067701&catid=20354
Beyond the obviously faster CPU, slightly larger HD and more memory, I also wonder if the shared video of the above turion is a serious drawback. Again, I don't play alot of games.
Anybody have feedback for me?
thanx
Ok, my rig is this:
MSI Neo2 Platinum
thanx
