Just got back from Bestbuy to check out the X1000.
Impression: a very solidly built machine. It looks sleek. The top casing is aluminum. The bottom is very sturdy plastic.
I am very impressed by the LCD casing. I try to press on it hard and the LCD did not distort. Good KB, good layout.
However, after seeing the X1000. I am even more convinced to keep my T40. In terms or "portability" rating, the T40 is much more portable. Even without the battery in the X1000, it was noticebily heavier than the T40. The thickness between the T40 (1in) and the X1000 (1.3in) was very noticeble. I just don't think the T40 and the X1000 are in the same "weight class". The diffrence is similar to using an 12.1inch thin notebook w/o optical drive(i.e. X22) vs a T23
That's not to say the X1000 was bad. In fact, compared to other HP, compaq, laptops at BB, the X1000 was much more portable. Also, if you are considering a Dell 600m vs X1000, definately get the X1000. THe feel of the weight between the two arevery close.
Having said all that, I may be biased or overcritical of weight and size in laptops. My preious laptops are: Sony Z505, R505, Dell 600M, IBM x22.
Also, one more factor to consider if you are deciding between the T40 and X1000. IBM's warranty for T40 is 3 years. It's $200 extra for the Compaq to have 3 years warranty.
