Compaq IPAQ Compact Flash Speed?
gopunk
29,239
how fast can the 3635 write to the compact flash? i don't want to buy flash that is too slow or too fast.... thanks!
gopunk
29,239
well i guess both read and write. basically, what brand of compact flash shoudl i get for my 3635? :)
OS
15,581
DP CF review
That being said, CF speed differences tend to be exaggerated especially when used in consumer devices. I'd just buy whatever is cheap.
gopunk
29,239
hmm... well is there a brand that is more reliable? i don't really like buying stuff based on price alone :)
OS
15,581
Once you get past infant mortality, I don't believe so. All the CF on market are manufactured by a handful of companies. However, if you are that concerned, any big name brand will do since they will probably provide better support than say mr flash.
cavingjan
1,719
Also consider battery life. Some compact flash cards drain the life out of batteries quicker than others.
Supahfreak
1,378
The tranfer rate if awful though the cradle no matter what brand CF you use. Need to get me a USB CF writer...
FreAk
Supahfreak
1,378
<< Once you get past infant mortality, I don't believe so. All the CF on market are manufactured by a handful of companies. However, if you are that concerned, any big name brand will do since they will probably provide better support than say mr flash. >>
Yeah, but look at those prices at NewEgg
FreAk:D
gopunk
29,239
<< The tranfer rate if awful though the cradle no matter what brand CF you use. Need to get me a USB CF writer... >>
does that affect pdas?
Supahfreak
1,378
<< does that affect pdas? >>
Yeah, I have a 3635 and tranfer data though the cradle and its really SLOWWWWWWW. My friend has a Jornada but he uses a Flash reader/writer instead, says it's way faster. Gonna get one when I get some money together, hope this helps...
FreAk:D
