Compaq battery problem
dynasty
398
I just reinstalled windows on a compaq presario laptop. Now the battery doesn't seem like it will hold a charge. Whenever I take the Ac adapter out the laptop turns off. A friend of mine said something about a battery firmware? I appreciate any help, the battery was working fine before the format.
fbrdphreak
17,555
No battery firmware that I've ever heard of.
Did you use the same OS (i.e. format XP to XP)?
I would shut down, remove the battery, connect AC, boot up, and put battery in while running. Go to Control Panel --> Power Settings and see if the battery is recognized.
