Quoting myself
You have a low freon charge, this causes cycling of the A/C compressor.
This is true to a certain extent, it depends on the settings of the A/C thermostatic control and the efficiancy of that particular A/C system.
If you don't want to converse in a friendly manner, don't converse at all.
Really? So a computer controleld fuel injected engine sees no performance loss from high ambient air temperatures? Hmmm.. But even if the computer adjusted the mixture, wouldn't you still be netting less power, since it would have to reduce the fuel charge.. and then you'd have to step on the gas just a bit more?
Yes, but you must understand that we are talking about
engine efficiancy everyone is confusing this with fuel mixture, these are two completely seperate issues.
Does engine efficiancy drop because of temperature changes ?
No, it does not, only the amount of power and the amount of fuel injected changes
There is a direct relationship between the amount of fuel burned and rated output, this relationship does not change with outside ambient temperature.
What is going on ?
My posts are getting all screwed up
Geebus, are the gods mad at me today.
Now, if the vehicle is carbureted, then you will see a reduction in fuel mileage because the carb cannot change the mixture ratio to compensate, this is why drag racers take temp and barometric readings and swap jets accordingly.
