Cold boot problem - Gigabyte MA790XT-UD4P
lex76
I have cold boot problem with my "Gigabyte MA790XT-UD4P" motherboard. It worked fine for a few weeks, and suddenly problems started. After pressing power on - boot starts and after a few seconds boot manager shows (till now, everything is fine). When I choose operating system, either Windows (XP 32-bit), either Linux (Mint Gloria 64-bit) - OS loading starts and after some time (3 - 10 seconds) computer freezes. Ctrl+Alt+Del doesn't work, only reset button do the job of restarting computer. After few attempts (10 days ago one reset was enough but today I have to restart like this for 4 or 5 times) OS loads and I can work without any problems. Also, if computer restart (warm boot) is needed - it works fine. But if I turn computer off, and after few hours try to turn it on again - same problem appears. Does anyone have any idea what to do / where to look?
My configuration:
1 x CoolerMaster Elite 334, black, (W)187 x (H)421 x (L)485 mm, 6kg
1 x Napajanje CORSAIR 550W, VX Series CMPSU-550VXEU, 12cm vent., ATX
1 x Gigabyte MA790XT-UD4P, AMD 790X+SB750, S. AM3, 8xSATA RAID, DDR3
2 x DDR3 4GB (2x2GB) Corsair, 1600MHz, 9-9-9-24, COR-TW3X4G1600C9DHX
1 x Procesor AMD Phenom II X4 955 Black Edition, socket AM3, BOX
1 x HDD WD 1Tb, 1001FALS , SATA II, 32Mb Cache, WD Caviar Black, 72
1 x DVD upisivac Pioneer DVR-117FBK, DVD±RW, 22x crn , ATA
1 x XFX HD4850 512MB DDR3 625MHz, Dual DVI, HDTV out, HDCP ready
lex76
Well, it turned out that disabling C1E option in BIOS helped me. I have no idea why is that, but... it works!
