Agreed. That and better tires will make a huge difference that you can appreciate. Anything short of forced induction isn't going to make your car noticeably faster. Well, you could go full-tilt and build the motor for high compression but that's certainly not trivial either.
The TL-S bar should bolt right in to your TSX and costs like $50. Can't go wrong. Made a big difference in my Accord.
doesn't a stiffer RSB induce a bit MORE rotation/oversteer? (in addition to making turn-in sharper)
In this application, the TSX routinely runs up above the 17:1 range. While it's not quite as lean as Honda's stratified charge type systems, it's designed to run properly quite a bit above the stoichiometric ideal. It runs a NOx catalyst specifically for the lean burn.
Otherwise, I agree with the stoichiometric ideal for your typical 3-way converter equipped systems.
Many have measured a CAI for my MS3 as adding 25whp, and even larger off-peak gains. If the CAI improves over the OE design it might very well add noticeable power. FWIW my MS3's CAI is an AEM unit, and IMHO they know what they're doing.
ORLY? Are you talking about the "factory" Mazdaspeed CAI from their catalog? That's what I have in my MS6. It got rid of that anemic feeling at high RPMs and gave my butt-dyno a few more hundred RPMs of pull, plus added some noise. I didn't know it added actual measurable power.
yea the ms3 takes to the intake well, i had the cobb intake and it was +14hp but it completely made 1st and most of 2nd gear useless as it reached redline quick, and 3rd gear pulls were a lot stronger. i also had the turbo inlet.
It most certainly does, 10-11% more HP and TQ. I also noticed a small bump in fuel economy too.
With my winter tires on now... 1st and 2nd can spin at will :awe:
Yep, a stiffer RSB reduces grip in the rear by increasing weight transfer, pushing the cars balance toward over-steer. I don't think it will really improve turn-in response, but it will make the car rotate a little more easily.
It prevents positive camber on the outside wheel, which means you keep contact with the road. In that sense, it prevents you from having the back end swing out on you, thus allowing you to corner better. It does NOT reduce grip.
ClubRSX has done some fairly extensive testing of the different intakes available for the K20A2, here: http://www.clubrsx.com/cr/SSPTIT.html
