JulesMaximus
Originally posted by: Arcadio
I knew that. That's why I use random.org every time I need a random event instead of a coin flip.
What if you're not near a computer? Oh wait, this is ATOT...nevermind.
Conclusion:
Despite these important caveats we consider the bias we have
found fascinating. The discussion also highlights the true difficulty of carefully studying
random phenomena. If we have this much trouble analyzing a common coin
toss, the reader can imagine the difficulty we have with interpreting typical stochastic
assumptions in an econometric analysis.
The caveats and analysis also point to the following conclusion: Keller?s analysis
gives a good approximation for tossed coins. To detect the departures of the order of
magnitude we have found would require 250,000 tosses. The classical assumptions of
independence with probability 1/2 are pretty solid.
(minor thread-jack)Originally posted by: Fox5
Originally posted by: her209
Fake phone numberOriginally posted by: mundane
Okay, I'll bite. Why would you need a random number in your daily life?Originally posted by: Arcadio
I've been using python's random class to generate a random number whenever I needed one. Generally for choosing maps in multiplayer games.
I use an electronic dice roller (LEDs that light up) that I made for general random decisions throughout my life. It doesn't really give random output though.
This may well be the world's only discreet logic circuit to generate truly random output.
The 200Hz oscillator samples the phase noise of the 2MHz oscillator yielding a truly random coin-toss output.
Uh ohOriginally posted by: Regs
This is like...multiplying any number by 0.
Originally posted by: GodlessAstronomer
Originally posted by: SunSamurai
What the hell? Coins arnt separate from the laws of nature?
But... they are COINS.
Read the full article, that's not the point. The main conclusion here is that when human beings flip coins, the outcome isn't random. Traditionally we have assumed that the outcome should be essentially random due to chaos theory - small differences in the initial conditions lead to large variations in how the coin behaves. This article shows that this doesn't lead to true randomness.
Originally posted by: moparacer
Funny this topic should come up this week.
I was at the drag races Saturday night and when you and your opponent want the same lane you have to flip a coin for lane choice. I never really give much thought to the whole coin flip process and while he was looking for a quarter I decided since I had called heads the last 3 times and won, I would call tails this time....
He flipped it, it came up heads, and I ended up losing the round.......
randomness fail
Originally posted by: SunnyD
I've come to a science myself flipping coins. Using my technique, I can influence the outcome to about a 75% accuracy.
Yeah no shit, that's what I was implying. Nothing is truely random. Random cannot exist. Even things like the uncertainty principle only apply to human capability to measure, they do not extend to what actually is.
A toss is only random enough because we have no practical way to determine it before hand. That doesn't mean its not governed by strict laws
(minor thread-jack)
Any thoughts on this?
Its claim:
It might become a side project eventually.
I've tried a few commercially-available LED candles, and I've found this:
Philips LED candles don't flicker. They blink. It's very obvious that it's nothing close to a candle.
Various other candles that come close to a flickering behavior seem to have a repeating pattern after a minute or so, similar to cheap white noise generators. Two of them side by side will eventually sync up, much like turn signals which are timed with different frequencies; at certain points in the cycle, they appear to nearly sync up.
randomness fail
Originally posted by: JS80
lol shens that coin flip is 51%
Well you'd certainly know better than the researchers :roll:
Originally posted by: CoinOperatedBoy
Paging Chiropteran
Yeah, we all know they never skew any results to fit their theories... 😕
Originally posted by: DAPUNISHER
All I know is, when we flip a coin over something, it has to hit the ground and bounce around. 😉
Originally posted by: Jeff7
I've also heard that a cheap way to create random noise is to take a CCD, enclose it in a completely dark, cold container, and boost its gain. The static generated would then be random, the product of electron vibration or motion, or some such thing.
