- Jul 5, 2000
- 5,988
- 110
- 106
I had a coil pack replaced on a 2012 Dodge Avenger, due to P0306 code. Cylinder 6 misfire. 5 days later, same code pops up. It works, just fails once in a while. On the original coil pack, I cleared the code and 20 minutes later it pops up again.
While the work is still under warranty and I plan to take it back the the shop. What could be causing the coil pack to fail. Is there something that controls things about the coil pack?
Update:
The mechanic did some standard testing they did the first time around, fuel pressure check and few other things with cold and hot engine and all checked out fine.
To get access to the coil packs, sparks plugs, compression testing, and leak test, they let have to remove upper intake manifold. Cold engine compression testing and leak test (0.04) showed it being good. They then ran the engine for 2 hours and repeated the compression testing, which was good; then the leak test, not so good. 0.50? IIRC.
The garage shop said Dodge has a TSB for that particular cylinder head and it should be free for me to get it fixed once Dodge does all their diagnostics testing and come to the same conclusion, due to there being some kind of extended warranty.
Related article: http://www.torquenews.com/106/chrysler-replacing-cylinder-heads-select-pentastar-v6-powered-models
A website reports left cylinder head gets 10 year 150,000 mile warranty: http://www.allpar.com/news/2014/06/chrysler-stands-behind-heads-25322
Update 2:
Took it into the dealer on a Wednesday and they confirmed that the head will need to be replaced. Diagnostic fee, $120, will be waved. Part comes in on a Tuesday, unknown at this point when it gets back to me.
Update:
Update 2:
