Coffee Lake Overclocking Thread, Why Not - Sharing is Caring
Geforce man
1,737
11
and here I had just decided that my 6700k @ 4.6Ghz delidded @ 65c max temps was more than enough (on air). Silly me.
LTC8K6
28,520
1,576
Pretty easy to see if it's throttling. In HWinfo Set your polling speed to highest setting, and reset the clock just after you start cinebench run.
looking at your IBT, looks like it might have been throttling there also? Look at your your min max and avg.
Yes, IBT score is quite low.
Chrisch
29
38
46
here some benches with my 8600K @ 5.4GHz
my daily setting (with AVX load)
5.5GHz boot with ~1.38-1.4v vcore, but this isnt stable for cinebench ;)
Intel Core i5 @ 5500 MHz - CPU-Z VALIDATOR
firewolfsm
1,848
29
Does anyone have a non-k processor? Can anyone confirm if the BCLK can still be set to 103Mhz on non-K processors? And if the uncore can be overclocked?
StinkyPinky
6,985
1,283
My system is up and running, no time to overclock it yet though. Will try in the next day or so.
StinkyPinky
6,985
1,283
What voltage do you guys think is a safer long term one? 1.35?
I hit 5 on my 8700k pretty easily so I'm thinking I may be able to get 5.1 at or below 1.35.
TahoeDust
557
404
I would say as much as you can cool under 1.4v. You will probably hit the thermal wall before that. Just make sure you set a reasonable AVX offset. Don't let the heat produced by AVX limit your non AVX overclock. You probably already do something similar, but I adopted this practice when working on my 7820x...
1) Set desired clock and max acceptable voltage
2) Use Cinebench for quick stability test, lowering voltage each time it passes to find lower passable voltage
3) Use Prime95 v26.6 ~30 minutes to test thermals/stability without AVX increasing voltage after every crash until stable...if thermals are too high, lower clock and go back to step one.
4) Use Prime95 v29.1 ~30 minutes to check thermals/stability with AVX. If too hot or unstable with AVX, increase AVX offset.
Once stable and with acceptable temps move on to longer stability testing.
EliteRetard
6,490
1,022
It looks to me like all modern CPUs (AMD and Intel) now have a safe limit around 1.35v with a "risky" 24/7 limit of 1.4v (with very good cooling). Same numbers for DDR4, that makes it all easy to remember.
AdamK47
3,620
I do like the memory overclocks with the 8700K. It looks like I'll be able to run the same 4133 CAS16 settings on an 8700K / Z370 setup as I do now with my 7740X / X299. That is, if the 8700K ever becomes available.
EliteRetard
6,490
1,022
I'm curious, how'd you get a free 7740X?
Obviously nobody would ever pay for one...
Reactions: Grazick
Chrisch
29
38
46
No not stable, only stable enough for a CB run :D
5.3GHz is the max which i tested with prime (non-AVX).
Btw its a custom loop (Heatkiller IV Pro with 480 radiator).
Bouowmx
1,150
553
How overclockable is cache/ring/uncore frequency? I ask because I run an app that sees tangible benefits from reducing memory subsystem latency (uncore and main memory). Of course, core frequency is still king.
