I have a CM690 case and when I use an intake fan on the side panel it make a loud buzzing noise like an airplane propeller. I tried an Antec fan and the CM fan the case came with, no difference in sound. I tried the Antec fan on another case and it was quiet so I think it's the case design that's causing it as I read someone else having the problem with this case. Would installing washers inbetween the side panel and fan make it much quieter or is there a special fan I need to avoid this noise problem when using a side panel intake fan? The reason why I want to use a side intake fan was because my GTX 580 runs cooler with a side intake fan. The front intake fan is blocked by the hard drive cage.
