I don't think you understand how a drive is laid out. MBRs, partition tables, disk signatures, LDM databases, extended boot records are not included in a partition clone. So, YES it makes a difference if you are cloning a partition or a disk.Originally posted by: pcgeek11
smilin,
It doesn't make any difference if it is a drive level clone or a partition level clone.
I don't mind you quoting me at all. If I need to make a guess I'll tell you when I'm doing it. If what he did was perfect he wouldn't have had a problem. Unless of course you think it's impossible to make a clone of a disk with Ghost without this error." A little care upfront will avoid this though. "
Like what? What he did sounds perfect to me. If you know what he did wrong, please let us know! I would like to hear this myself. If you don't mind me quoting you:
" Smells like guesses in here "
" You used a product A, had problems, never found root cause, switched to product B and the problem went away. In your eyes product A has problems and B doesn't. "
In everyones eyes product A has problems, I have used Ghost many many times and it was a hit and miss operation, sometimes it worked sometimes it didn't. I switched to Acronis and cloned hundreds of drives and partitions and it has worked perfectly everytime. What conclusion would you make ?
" I'm glad you're happy with the outcome, but you shouldn't be. "
Why not ?
Bologna
pcgeek11
"A man who doesn't learn from his mistakes is doomed to repeat them."
Something is only hit-or-miss if you never bother to find out what went wrong when you get a "miss". Since you never found the root cause you can't conclude what it is. You are merely making an assumption that it was Ghost. You could be right, but you don't really know do you? You seem sensitive to criticism which is unfortunate because you could be picking up some free knowledge here that might help you in the future.
Since this problem is gone and the thread owner is happy with the outcome this is all a moot discussion. The egos seem a bit large here so things may quickly degenerate into some sort of pissing contest. I'm quite confident in my views on this matter so I'll be more than happy to agree to disagree and walk away if you would like.
