Climate Science Is Not Settled
Page 20 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Nov 30, 2006
15,456
389
121
The "pause" is now up to 18 years effective 10/1/14.
JockoJohnson
1,417
60
Wrong. You must have CBD.
On a more serious note, the "pause" must be due to all of the regulations put in place. In order to make it work even more gooder, we need to put more regulations in place.
OverVolt
14,278
89
Doc, is there a reason you ignore the increase in ocean energy over the same period?
That's an increase of ~10x10^23J of energy during the "pause".
There's going to be an increase in heat no matter what entropy is kind of a bitch. :/
Jaskalas
36,370
10,679
Can you tell us how much land surface warming that should translate into? Could you specify WHEN that warming will occur?
Paratus
17,745
16,062
Sure
http://www.c2es.org/science-impacts/ipcc-summaries/fifth-assessment-report-working-group-1
Global surface temperature increases exceed 1.5 C and keep rising beyond 2100 in all scenarios except the lowest-emission scenario, in which actions are taken to nearly eliminate CO2 emissions in the second half of the 21st century. In the scenarios with higher rates of emissions, warming is likely to exceed 2 C by 2100, and could even exceed 4 C.
Now, I asked you why you are ignoring the large increase in ocean thermal energy during the "pause" in atmospheric. Endorsing the pause and then ignoring my quesiton is generally what I would expect a global warming denier to do. I believe in the past you've indicated you believe that the climate is warming and man has a part in that.
So help me out here. What's your position? Why is the pause meaningful but the increase in ocean energy meaningless.
simpletron
189
14
The mass of the oceans is ~1.4*10^21 Kg, so adding 10^23J energy would increase the average temperature by ~0.02C.
Nov 30, 2006
15,456
389
121
WTF? I'm not ignoring anything. I hear there's a theory going around that changing ocean currents could be driving heat into the deep sea (Tung and Chen). However, I'm not sure if you're aware of this or not, but there have been several theories attempting to explain the unexpected global temperature pause. If you actually think Tung and Chen's hypothesis is proven and the undeniable reason for the pause, then you might want to rethink the assumptions, facts and rationale you used to arrive at such a questionable conclusion. In case you haven't got the memo yet, the science is far from being settled on this issue.
“The rather strong conclusion that ‘the cause has been found’ is overblown” - Gavin Schmidt
Stewox
528
Let me ask OP the obvious (non)question here:
Was there ever any science in Climate Change at all ...
Jaskalas
36,370
10,679
Seems like a diversion to direct us towards general assumptions for the year 2100, as opposed to addressing the direct nature of the OHC's rise. First, the scale is in joules... because the change in temperature is quite small. Second, we're on land, so whatever we measure in OHC does not directly impact us.
Now you'll come back and tell us that this "extra heat" will find its way to the surface. Thus my request... when, and how much? You do not know. If the ocean does release this heat, would it not cool in response? Why does the OHC only ever show warming these past 40 years? Apparently our record does not demonstrate it releasing heat.
That brings into question the quality of the record. 40 years of continuous warming... but you'd have us believe it releases heat into the atmosphere. That it'll impact our surface temps. I trust Argo, but that's only an ~11 year record. Need 60 years to capture PDO / AMO.
Logically, if the oceans only ever warmed... our landmass temps should only ever warm. Your OHC argues that the pause shouldn't have happened. Is that not true?
I'd trust it more if OHC cooled while our surface warmed. That would demonstrate the exchange of heat, a direct cause and effect. Without that... something is very much wrong with OHC, or my understanding of it.
That'd explain it. Too small to matter. At that rate we can expect 0.2c by 2100?
Jaskalas
36,370
10,679
You asked Doc, not me, but I'll bite.
I do believe our CO2 warms the planet, but I'd be surprised if it's more than 0.5c per doubling. My position is that activists took the short term warming from the 80s - 90s and linearly extrapolated that out to foretell stories of man-made doom. Predictions based on those 20 years of warming are wildly short sighted.
I "ignore" OHC because, apparently, it's rise is worth a whole 0.02c. That and our quality record for it is ~11 years old. It is an incomplete and immature dataset comparing apples to oranges. I'd like its relationship to our air temp explained.
Paratus
17,745
16,062
And yet that small increase in temperature is equivalent to:
  • 23 million megatons of TNT
  • 20% the impact energy of the dinosaur killer asteroid from 65MYA (Chixulub)
  • enough energy to power a hurricane for 1923 days.
All while the "pause" was going on.
You Doc, stated the pause is now 18 years old. Then you stated you've ignored nothing when referring to the measurable repeatable proof that there has been an increase in energy. These are two mutually contradictory statements. WTF indeed.
The rest of your ramblings I'm having a hard time following. I am aware about the theory that energy is being retained by the ocean. In fact that's what the chart I linked to shows. But ocean currents aren't going to save your arguement that there is a pause. That extra energy can be moved around by ocean currents but it came from the sun. Your own pause plot shows no atmospheric cooling to offset the increase in the ocean. Thermodynamics says when a body increases in thermal energy its temperatue must rise until the radiated amount equals the incoming energy.
That science is settled. I can't stress that enough. Climate change is based on thermodynamics and conservation of energy. That is as settled as science gets. If you think that ocean currents are going to somehow hide this energy away or produce it somehow, I don't know what to tell you.
Jaskalas
36,370
10,679
Paratus, how can the pause exist if the oceans have done nothing but warm these past 40 years? They're supposed to be a regulator with wide, natural, variations. Yet all OHC shows is up up and away.
How did it cool the atmosphere if all it does is get hotter?
OverVolt
14,278
89
There you go the science is settled lulz. Cause thats how science works. One and done then its settled. Had a good laugh with my coffee alright then.
Both sides of this are officially stupid. Politics and science don't mix which would probably be your first clue that the science isn't all that great.
Paratus
17,745
16,062
1) No the scale is in 100,000,000,000,000,000,000,000J or as I said above equal to 23 million megatons of TNT.
If you aren't familiar with nuclear weapons the largest bomb ever designed was the Tsar Bomba by the USSR. It was designed with a yield of 100 megatons of TNT. They were afraid to test it at that yield and only detonated it at 50megatons.
The amount of energy the oceans have increased by is equal to 230,000 of those bombs the Russians were afraid to test.
2) "Doesn't effect us because we live on land". This comment literally just stopped me in my tracks. You have to understand how ocean temperatue affects us to argue climate change.
The energy in the oceans basically what drives the entire climate. Evaporation of water to drive clouds and storms requires energy. That energy comes from the sun. The more energy available in the water the more energy is available to drive storms, ocean currents, and air flow. Please investigate this.
This extra heat does not come from the ocean. It comes from the sun. If the earth were in energy balance the OHC would on average show no year to year increase.
Thermodynamics says that energy flows from areas of high concentration to areas of low concentration. The oceans are cold and the atmosphere is warm. Heat will flow into the oceans from the atmosphere. The upper ocean is warmer than the lower ocean so heat will move from the upper ocean to the lower ocean.
The OHC only shows warming these past 40 years because the changes in the atmosphere means the entire Earth as whole is gaining energy from the sun.
There can be no pause unless the land, sea, and air are ALL paused.
No the ocean on average doesn't warm the atmosohere. Sure it will at the poles where the ocean is warmer than the atmosphere, but globally on average the ocean is warming. It will only cool on average globally when the Earths temperature is high enough to radiate equal the incoming solar energy.
I'm sorry Jasklas it's your understanding of the climate thats wrong. What you've assumed is completely backwards. I'm not saying this to be insulting but what you've said is just plain wrong.
See above.
OverVolt
14,278
89
Storms are coming.
And rain. Hide yo kids hide yo wife. I've never seen the ocean evaporate H2O into the atmosphere and then see it fall back out of the sky in my whole lifetime. Everyone knows the day it rains is the day the planet is dieing.
Aside from that I remember watching discovery awhile ago and they said based on soil samples that 1,500 years ago there was a peak of hurricane activity and that we were overdue for a large increase in hurricanes based on historical norms and that the period of the last 1,500 years or so was actually a fluke of abnormal calm. So who knows. But your computer sim that they first ran on Pentium III's I'm sure is good science too. Plus all the stuff about nuclear bombs worth of energy in the ocean is very scary cause thats how scientists break things down. Hope we don't have any big 5,000 Tsar Bomba category hurricanes this year.
Paratus
17,745
16,062
Since you are on AT did you ever build your own rig? If you did you may have used a good air or water cooler on your CPU. When you turn on your computer the CPU heats, its temperatue begins to rise, and energy is transfered to the heat sink. The heat sink temperature begins to rise and it begins to transfer its heat to the flowing water in a water cooler.
Until the system reaches equilibrium the temperature of the CPU, heat sink, and water will continue to rise. Once in equilibrium the temperature will remain steady. If you measured the joules leaving the CPU to the heatsink and leaving the heatsink for the water they would be steady and equal.
If we turned down the pump on the water loop and less water flowed through the heatsink the temperature of the heatsink would increase. If you measured the joules arriving from the CPU they would be larger than the number of joules leaving into the water. Eventually the temperature of the system would reach equilibrium and the temperature increase would pause at the higher system temperature.
The reverse would happen if we increased the water flow through the system.
For the Earth, the sun is our heat source, (CPU), the continents, ocean, and atmosphere are our heatsink, and the Earths ability to radiate heat to space is our waterloop.
Climatologists claim that the increase in CO2 interferes with Earths ability to radiate heat, (turning down the pump in our waterloop metaphor). If that's true the temperature of our heat sink, continents, ocean, and atmosphere must warm.
They are.
Among others, one prediction from this would be less ice at the poles as a result of warmer land, ocean, atmosphere. That's what we see:
Reduced Artic ice cover:
Gravitational changes in Antartica from melting ice.
http://www.wired.com/2014/09/melting-antarctic-ice-shifting-gravity/
Paratus
17,745
16,062
Storms are coming.
Got a link to your Nobel prize winning paper overturning thermodynamics and conservation of energy?
No?
Well in that case I understand this guy is looking for investors:
http://ecat.com
Just plug it in and it makes more power then it uses. I'm sure you'll get rich. :sneaky:
