BoomerD
- Feb 26, 2006
- 66,560
- 14,961
- 146
I have a couple of months off work at the moment, and I would be more than happy to come down and fix her plumbing
Is Princess Ida is Kitty?
Take it to L&R...
You know the routine, pics and we will helpOkay. I've located the hot water supply and the cold water supply. All nicely new. Twisty valves are fine and easy to turn but the nuts are resistant.
If there's a quick and foolproof answer to the resistant-nut question, bring it on. But I'm not playing around with it just to see what happens. There's a limit. It's an apartment, darn it. With a very bad landlord.
So the side sprayer works fine? Hot and cold?
I'm thinking stuck diverter valve.
It is possible that the diverter is clogged if both hot cold are not working. But if only hot or cold is not working then it could be the cartridge.So the side sprayer works fine? Hot and cold?
Cycle the trigger on the sprayer on and off real fast.
Call the plumber to come back and fixit. Other wise post in the morning & I will walk you through the steps of disassemble & reassemble the faucet if you are handy enough to take on such a task.That was fun. Doesn't seem to help anything yet, but I'll keep doing it for the enjoyment.
Does water flow in the rest of the house? Are there cutoff valves under the sink? Unscrew, check hot, cold. Might want some pans or something to catch water with.
