XavierMace
I just blow mine out with the ShopVac.
... Having a properly filtered case has helped case cleanliness a LOT.
Great point! And here is another very good use for Swiffers. If you tape a Swiffer sheet across the air intakes, it will filter out and trap much of your dust and dirt.
Yes. Easiest is to build in a case that was designed with intake filters from the beginning, and then to keep fan RPMs reasonable, so as not to be pulling/pushing more dust through the case than necessary. Cable management and fan placement matter, to be able to get sufficient cooling as the fan speeds (and thus pressure) get lower (most popular cases, except the Antec dinosaurs, make this fairly easy).That's a great tip, but won't it inhibit airflow?
No. Been doing it for years - Swiffers are very loose when it comes to air flow. Put a clean one over your face and you'll breathe normally. They are treated to attract and hold dust particles.
OTOH, you need to replace them periodically, because the accumulation of dust can inhibit air flow. IOW, it is simply an effective poor man's filter.
