cleaning cat hair out of a computer power supply?
nova2
982
got some really clogged PSU's.
edit: what about cat hair?
it seems like the PSU would need to be opened up to get that out.
Atheus
7,313
Don't open it, even when turned off and disconnected the capacitors hold enough charge to kill you and the next guy next to you if you touch them.
If you know what you're doing you can discharge them, but I don't recommend it.
Jan 31, 2002
40,819
You're thinking CRTs. I've taken a direct hit from a faulty PSU, and while it hurt like a bitch and gave me a nice electrical burn, it sure as hell didn't do any last damage.
- M4H
Chaotic42
35,294
2,429
- M4H
Sounds like it blew you -ing off.
Jan 31, 2002
40,819
- M4H
I see I've got a brother in the shocked dept, you lost your r to a similar fate I take it?
OP - Compressed air should take out cat hair unless it's really thick. I'd be setting up a filter system if it's that bad that there's cat hair in your power supply. :p
- M4H
GalvanizedYankee
6,986
If it's old enough to be loaded with cat hair, open it up, blow it out while scrubbing it with a small new paint brush. Then replace the fan with one of the same spec.
The primary heat sink will probably be hot with 160VDC, if you power it up with the case open.
...Galvanized
Chaotic42
35,294
2,429
- M4H
- M4H
I'll neve sleep until 'r' is taken out of the Latin Alphabet.
Auric
9,591
If you not cazy now you'll go cazy fom no sleep!
As fo the hai poblem, ty mild soap and a damp cat.
corkyg
Elite Member | Peripherals
27,370
240
First, I would remove the PSU from the computer.
Second I would open it up. It is not necessary to touch the caps.
Third, I would then vacuum all of the hair out with a crevice tool or smaller. (I have computer tools for that.)
(No need to blow the hair around to get into everything else.)
Fourth, I would shoot the cat, skin it, and nail the hide to the computer room door to warn all future felines! :)
