- Mar 18, 2007
- 11,959
- 157
- 106
Originally posted by: xtknight
Microfiber cloth or a soft tissue damp with distilled water (hard water is usually fine).
A tissue like a tissue you blow your nose in?
<div class="FTQUOTE"><begin quote>Originally posted by: pcslookout
<div class="FTQUOTE"><begin quote>Originally posted by: xtknight
Microfiber cloth or a soft tissue damp with distilled water (hard water is usually fine).</end quote></div>
A tissue like a tissue you blow your nose in?</end quote></div>
Sure. I just clean my glossy panel with hard water and Kleenex. It's always been fairly squeeky clean although I bet you could achieve better results with very thin cloth and soft water.
Yeah turning it off is a good idea just because water can damage electrical components. I think you should be able to start cleaning immediately after turning the LCD off. There's no reason you should have to turn off your PC.
Hrm...Originally posted by: n7
Monster Cleaner.
Monster Cleaner.
Seriously.
I think i've seen this same question asked 200 times over the years i've been on AT, & everyone who uses Monster Cleaner agrees it's fantastic.
Yes, i personally use it. No, i don't recommend Monster cables, but their cleaner = teh bestest.
