Originally posted by: grimdeath
omg, windex are you NUTZ??!?!? not all but certain crt's have a special spraying on the glass that keeps glare down, the strong cleaners eat away at that and can mess that layer up....do whatever you want, but i recommend water :/
Originally posted by: OAKside24
I tried 90% alcohol... -Don't do it Cap'n-
Windex absolutely worked great. No streaks, no residue.
Do they still sell the ammonia Windex? I have a very [ten year?] old bottle
that says ammonia free, I guess they 'figured it out' it doesn't sell
and is harmful a long time ago. But the new Windex I actually used was prolly
a bit more advanced, worked great. [For laptop cleaning also.]
Used a microfiber 'disc cleaner' cloth which cleans particles/dust off quite well.
[Windex for the smudges.] And yes you can reuse those, in reply to the question.
Works well on CRT TVs also.
Originally posted by: Deinonych
I've used these for years. They're convenient to use, and they don't remove the anti-glare coating.
Originally posted by: alimoalem
when u use the microfiber cloths, do you keep reusing it? i'm new to this microfiber thing...i'm still on using windex and paper towels
