Clean Case Wiring
yezhou
269
Originally posted by: LifeStealer
Its evolved beyond the need for a hard drive.
LOL :D
But seriously Mik3y, your friend's computer......O-M-F-G!! :beer::thumbsup::cookie:
P.S. What case is that?
Tiamat
14,068
LOL :D
Looks like the Coolermaster cases the many people drooled over but couldnt afford back in the day (3 years ago?). ATC 201 or ATC 210 i believe. Friggen beauties of cases. Cant really find them these days.
Tankengine9
22
Yeah its the Coolermaster ATC 210
How about the water cooling system? is it custom built? or do you think he has a kit?
Mik3y
Banned
Mar 2, 2004
7,089
its a danger den water cooling system. go to www.dangerdenstore.com to check it out. he used the maze 4 line of water blocks and the xtreme I radiator.
Mik3y
Banned
Mar 2, 2004
7,089
the reservoir is in the top 5.25 inch bay(s), depending on whether he used to single or dual one.
Tankengine9
22
hey mike, i would like to build the same thing,
i have the BFG 6800 ultra video card that requires water cooling, and i really like his system so i would like to build something similar,
the only thing im after is getting the water cooling system internally,
what other parts is he using, i am new at the water cooling thing
i see he has a T tube, what is the part on the roof of the case? the pump? and on the lower right hand side is the reservoir? but where does that 1 tube go to?
im a newbie that this
thanks for all the help
Mik3y
Banned
Mar 2, 2004
7,089
the top is the radiator, the drive bays are the reservoir, and and the bottom front is the pump. note that he had to mod the case at the top sto support the radiator. he used the xtreme I, which is a single 120mm radiator and fan. the top of the case us cut to allow air to flow out. this is just one way of doing it, but is likely the best looking. what case do u have tankengine? how many drive bays do u have open? for the cpu, video, and chipset, i'd recommend the dual drive bay resorvoir.
Tankengine9
22
Hey mik3y
i have a regulare joe blow case, i think i should get a new one
i have a chaintech znf150 m/b with amd 64 3400
i only have a dvd burner
only reason why i would like to cool everything with water is because the vid card needs it so why dont i just do it all right?
Mik3y
Banned
Mar 2, 2004
7,089
sure. there's nothing wrong with water cooling a system...besides price. :) in your case, you'll need/want:
? Danger Den Maze 4 Water Block For Socket 754/939/940 CPU $35
? Danger Den Maze 4 Motherboard Chipset Water Block $43
? Danger Den Maze 4 GPU Water Block For nVidia & ATI Cards $40
? Danger Den DD12V-D4 Water Pump For Liquid Cooling System $75
? Danger Den Black Ice Xtreme Radiator For Liquid Cooling System $66
? Danger Den Dual 5 1/4" Bay Reservoir For Liquid Cooling System $32
it's pretty pricey, but you'll have to shed $300 ($291 to be exact) for just the water cooling system. you will be able to get ultra extreme oc's tho. as for a case, if you want that same case, i know of a place where you can still find it.
Tankengine9
22
actually i need The Danger Den 6800 Solution for GPU and RAM cooling.
for 124.99 USD actually
i have the BFG 6800
Mik3y
Banned
Mar 2, 2004
7,089
i have the BFG 6800
oops, you're correct. so ya, that's $350ish for water cooling, lol. :)
Mik3y
Banned
Mar 2, 2004
7,089
i think he got them from the same site under tubing. if not, i'll go ask my friend.
Mik3y
Banned
Mar 2, 2004
7,089
Originally posted by: Thurgo0dy
Go here if you want to see exactly how he did it.;) and here are some more pics of his system.
coolness. my friend knows that dude. :) well, knows him from online chat and forums.
Mik3y
Banned
Mar 2, 2004
7,089
Originally posted by: xbassman
While my case isn't nearly as cool as the one Mik3y posted here's a few pics.....
1.
2.
3.
holy crap! that looks soooo good. i totally dig that. you get a :thumbsup: on that for creativity.
then you get a :cookie: and :beer: for looks. :)
Mik3y
Banned
Mar 2, 2004
7,089
Originally posted by: ComatoseDelirium
Woo Mik3y how much did it cost for your friend to do that cooling system upgrade? roughly?
i 0n0. i dont know the guy. that dude is my friend's friend who he's met from online.
duragezic
11,234
4
So can you simply take a exacto knife or razor blade and cut up a IDE ribbon cable so that it could be bundled up? Or is it pretty risky to cut through and hit a wire?
Nice, clean pics all! This makes me really want to clean up the inside of mine, but I'm not sure where to start. It's pretty crammed in there.
Safeway
12,075
11
Just buy rounded, they are cheap enough. The chance of slicing the ribbon is too great.
