GTX 1060 ahead of Fury X and 27% faster than RX 480 at 1080p.
Damn, would be quite the toss up between a 480 and a 1060 if one bought this AND BF1, wouldn't it.
The games apparently works just fine in DX11, even if AMD is far behind Nvidia.
1060 is also only 22% slower than 1080.
1080 is whopping 2% faster than 1070.
Anyone looking at these results can tell the game isn't running very well at all.
Is it limited to 90 fps?
Microsoft still allows free upgrades to Windows 10
Not everything is about graphics. The game has low performance, but that is because 1) they are using a demanding view, likely late in the game with a ton going on, and 2) because it is hugely CPU demanding when doing so. Most the game, when playing it, will most likely have much higher FPS, and a faster CPU and AMD improved overhead drivers (or just using Nvidia) are what will help the most.Those numbers show the game running anything but fine. Its not a graphically demanding game and its running like garbage.
The only complaint I have is load times when you first start the game or load a save for the first time, basically the same issue as 5. This is on an ssd as well. Turn time seems to be slightly faster but it's hard to truly tell this early into a game.
GTX 1060 6GB is pushing almost 50 FPS at 4K Ultra, extending its advantage to 30.2% faster than RX 480 8GB at this resolution. Does this look like not running well at all to you? Yet another game that will need a post launch DX12 patch to 'fix' lower than expected performance on AMD cards due to CPU driver overhead.
This is not a FPS, or at all your typical game.
Edit: I'll add to how Civ games behave, and why they don't look like they should be graphically demanding, but are. When you zoom out, you can see hundreds if not thousands of cells on the screen at once. Each cell has both animation going on, with several items and people in them. Even though they are small, they all steal GPU and CPU time, and since there are hundreds or thousands of them in view at a time, if zoomed out, performance gets hit much harder than your typical game.
You think that 1060 running faster than all of AMD's cards is normal?
Did either of you bother to watch the benchmark video?
There is absolutely nothing amazing happening at all in the scenes, hardly any animation anywhere and tons of frametime spikes all around, and that was on 980 Ti / 1070 / 1080 as they averaged over 80 fps @ 1080p.
Look at Civ V which ran fine on both AMD and Nvidia like I posted from Anandtech's benchmarks in Post 16
You will not see amazing graphics, because every scene that has decent looking graphics, is a tiny cell if zoomed out, but is rendered the same as if it were large. While you don't see everything that is going on in those cells, they are animated, and require both CPU and GPU time to render. This is NOT a first person shooter. It's not like anything you apparently play. Starcraft style gaming is the closest you'll get to this type of game in terms of demand.
Something is obviously wrong with the Fury X, if it only performs ~11% better than the rx 480 @ 1080p. Hopefully we'll see a fix for it soon, or maybe performance improvements from DX 12.
Although, the 1060 6gb has a 30% FPS advantage over the 480 which is also really abnormally high.
As a side note, I like that I already know what to expect from benchmark results these days based on who is posting the thread.
The Fury ran out of memory. 4GB is laughable, hence the laughable sales of the Fury range.
If you play zoomed out, just turn some graphical settings down. You won't notice a difference. But the thing is, these animations are there, they are just really small. Having a 1000 tiny rendered scenes is going to be more demanding than having 1 complex scene.Spending the time to render things which aren't output on the screen is opposite of optimized and the point I'm trying to make. There is no reason the game should be running so poorly for what graphics are displayed. This is a turn based game, not even RTS which has tons of AI logic that needs to be processed constantly.
I mean the same people that said AOTS looks terrible and performs bad while it was using real time lightning on every laser beam and was real time with advanced AI are calling this one optimized and performing well?
While this is an obvious troll post, it's puny 4gb is obviously why the 3gb 1060 performed better at 1080p.The Fury ran out of memory. 4GB is laughable, hence the laughable sales of the Fury range.
Quite sure this is incorrect....free upgrade finished end of July 2016
I doubt it. It's likely a CPU limitation, as the Radeon scores illustrate.. DX12 should easily rectify this though..
Doesn't take a genius to figure out there is a CPU bottleneck.1060 is also only 22% slower than 1080.
It is great optimized not because it running better only on Nvidia but , in fact it is it is running better for more then 80% PC users on DX11.
