One of two schoolhouse pendants at original light locations. I used different extensions on the pendants to get the globes on the same level with the sloping ceiling.
finished vanity and lower cabinet
upper cabinet and medicine cab. The Medicine cabinet was originally in honey oak (gag). We tried refinishing it (double gag). I knocked the oak off and re-faced it with matching cherry.
With the LED vanity lights on
lower cabinet 3 sided towel drawer. All shelf surfaces are formica for toughness, edges are solid cherry pieces. Forced air duct was smaller due to furred out wall, so I made a wood grille.
Garbage bag holder on back of door. Other than the screws to hold it on, all mortise/tenon or halved joints with no fasteners.
Transitions from leftover cherry. Not the best color for it but the cherry is very hard and what I had on hand.
Toe kick is recessed in about 8" so the cabinets appears to float out there.
The heated floor is the bomb. Easily the best ~250 ever spent on a DIY job.
It is programmed to come on 30 minutes before the alarm, heats the tile to a toasty 82 degrees.
http://www.ebay.com/itm/30-sqft-120...58867719?pt=Tile_Flooring&hash=item3a80321007
Add two bags of self leveling concrete and a quart of primer, then tile.
