Christmas build rating, looking for suggestions I may not have thought of
Which Seagates do you like currently? Like I mentioned in my original post, I haven't used them in years but I'm not opposed to them.
The STX000DM001 (where X is the capacity in terabytes) series are good. They all use the same 1TB platters, but the higher capacity drives have more of them.
I'm sure you have more experience than me with this, but why do they list it as compatible in their datasheet if running it out of spec will damage the controller?
http://www.intel.com/content/dam/ww...sheets/core-i7-memory-suppliers-datasheet.pdf
More specifically, most of the ram listed for XMP profiles is over 1.5v.
They are "compatible" in that they will work and won't cause your PC to instantly burst into flames. But they are out of spec and expose the controller to stresses it wasn't designed to tolerate.
The stuff here was written by marketing folks, the datasheets that you and I linked were written by engineers. 'Nuff said. 🙂
That build looks very similar to what I just put together. A couple opinions:
1) Go with NVIDIA if you're doing 2 cards, not only is the price not a very big deal when you consider you total system cost, but SLI has better support and scaling, comes with better features (experience, shadowplay) and they will run considerably cooler (I got blower coolers with my SLI 780ti's).
2) If you aren't doing any video editing/3d modeling you can probably get away with an i5-4670k, but I understand if you want the flagship Haswell. I plan on doing more video editing myself with Shadowplay so I went with the i7 but it's a $120 premium for the HT, the gaming and OS performance is exactly the same.
3) Grab a Corsair 750D case instead of the HAF and take the money you save and buy Noctua NF-A14 flx case fans to replace the stock fans. The case will be quieter, look cleaner, be much easier to cable manage and the replacement fans will keep it cooler (and allow you to set up positive airflow with a fan controller if you get one). I built my new machine in that case and it's awesome. You also don't get the impossible to dust front panel (the HAF has those square molding that are impossible to clean).
3) Go with a 2x8GB ram kit, the performance isn't really any different and it will make sure you don't have RAM clearance issues with your cooler. If you want to water cool I would go with the Cooler Master Glacer 240L, it's the replacement in the US for the Swiftech H220 and it's way better than the one you have on there. I'd take a Noctua u14s over the ones that seem to have high pump failure rates. Just my personal opinion though, it's up to you.
I also went with Samsung 840 SSD (pro 256gb) and WD black HDD (2tb) because I wanted the best SSD for performance and a brand I trust explicitly for my storage drive. I've had great luck in the past with WD so I gave them the benefit of the doubt and paid a little more. If you're interested in my build:
Intel i7-4770k
Asus Maximus VI Formula
Corsair AX1200i
Corsair Vengeance Pro 16gb 1866
Corsair 750D
2x EVGA GTX 780ti superclocked (reference cooler)
Samsung 840 pro 256gb
WD black 2TB HDD
Noctua u14s with extra NF-a15 for push/pull
Prolimatech pk-3 thermal compound
3x Bitfenix spectre pro LED (140mm exhaust for top/rear)
2x Noctua NF-A14 flx (140mm intake for front)
1x Noctua NF-F12 (120mm bot intake)
I could have dropped to the Hero, went with the i5, and gotten the AX860i instead but I decided to go all out on z87. I had a bit higher budget than you so I also got an individually sleeved Corsair cable kit, a new mouse and a monitor, but your machine will be every bit as fast. The 780ti's are SCREAMING, they overclock decently too. I've got a pretty modest +75mhz on my core's but I just wanted to get a tiny bump, not go for aggressive overclocks on them. If you want to see pictures of my build PM me and I'll link you to my build thread on another forum since I don't want to repost everything...
I think I am going to go with the TI's. I've had good luck with SLI in the past and if I'm going to splurge someplace I would probably do it on those.
I snagged a 4770k for $216 w/ tax at Microcenter last weekend so I am set on that part now.
The HAFX is one of the few parts I had already purchased when I made this post. So I'm going to have to deal with it. After seeing it in person I dont think it will pose any problems. I was going to run Noctuas but got a good deal on Cougar Vortex's for only 10$ a piece.
Wish I would have known about the 240L about 4 hours ago. Just pulled the trigger on a h100i on newegg for only $85 after rebate. I do have some experience with the Corsair setups and they have performed well, although I woulkdnt have minded giving the 240L a shot.
Why did you go with the Formula vs the Hero? What speed ram did you run?
True enough, sort of like required and recommended specs for games 🙂 As others have said, I dont think I'll notice a difference between most of the speeds anyways so I'll just shop on price these next few days for a 2x8. Thanks again.
IMHO the GTX 780 Ti is not worthwhile over the GTX 780 because it costs 40% more and is at most 20% faster. GTX 780 SLI is already crazy fast for 2560x1600.
