Choosing between two laptops
skaertus
218
28
I am thinking of buying a new laptop and I am in doubt between two models. I live in Brazil, and prices here are astonishingly high. In addition, there is no wide availability like in the U.S. so I cannot simply choose model "X" instead of the two mentioned below. It is basically the two of them.
ModelLG Gram 17z90pDell XPS 13 9310-MS20S
Screen size17-inch non-touch13.4-inch touch
Screen resolution2560x1600 (16:10)3840x2400 (16:10)
Color accuracy99% DCI-P390% DCI-P3, 100% Adobe RGB
Brightness350 nits500 nits
ProcessorIntel Core i7-1165g7 2.8 GHz (max 4.7 GHz) 12 MB L3 cacheIntel Core i7-1185g7 3.0 GHz (max 4.8 GHz) 12 MB L3 cache
Graphics cardIntel Iris Xe GraphicsIntel Iris Xe Graphics
Memory16 GB LPDDR4x 4266 MHz16 GB LPDDR4x 4266 MHz
Storage512 GB SSD NVMe M.21 TB SSD NVMe M.2
Battery80 Wh52 Wh
Audio2x 2.0W DTS2x 2.5W Dolby
Key travel1.65mm1mm
Webcam720p720p
WirelessIntel Wi-Fi 6 AX201.D2WG.NVW (Wi-Fi 6), Bluetooth 5.1Killer Wireless AX1650 (802.11ax 2x2, WiFi 6), Bluetooth 5.1
Ports2x USB-C/Thunderbolt 4, 2x USB 3.1, HDMI, UFS/Micro-SD Card reader, headset2x USB-C/Thunderbolt 4, Micro-SD reader, headset
Weight1.35 kg (2.98 lbs)1.27 kg (2.8 lbs)
Price (in Brazil)$1750$1950
Price is very similar for both of them. The LG Gram has a larger screen and seems to have better battery life, but the Dell XPS 13 has a sharper and brighter screen. Any recommendation from real-life usage?
Shmee
8,313
3,177
Hard to say, it depends what you want to use it for. Other things to consider is the Dell has a slightly better CPU and twice the storage capacity, as well as a higher res screen, but also fewer ports.
Reactions: Cy_kkm
mrchips01
Battery80 Wh52 Wh
Key travel1.65mm1mm
Webcam720p720p
According to specifications The Lg Gram 17 is a better option, As Performance,display , gaming experience and battery life is better in gram 17 as compared to dell xps.
I think you should go for LG gram as there is not much difference in price but you will get a better device.
fire400
5,204
21
LG laptop CS will probably be no better than Dell, especially in S. America.
You have an ultra portable, and a wider laptop.
Native resolution for font stenciling on the Dell is going to look horrible. You have a 4K screen smashed into what is smaller than the recommended 15.6" 4K screen, even the ThinkPad X1 Yoga with the 4K screen is extremely microscopic.
If you're viewing high resolution photos and videos, and need something compact, then choose the Dell.
Should you want to enjoy the larger screen, but don't need 4K, then get the LG laptop.
If you truly want to save money and need the upgrades over aesthetics, just get a real workstation laptop that offers better modularity upgrades than the Dell or LG listed above.
Lenovo ThinkPads are widely available, almost everywhere in the world.
skaertus
218
28
LG. Screw Dell and their CS.
Thank you for the advice.
I ended up going with the LG Gram 17, as I found it for sale. It is a great laptop, and I think I like its build better than the Dell XPS.
By the way, I already have a desktop. This laptop will be my companion for traveling. I had other laptops with smaller screens, but this large screen is great for multi-tasking.
