One of the best discussions I have ever read on anandtech. Very accurate info and smart spending too.
HT is very premium to pay for as Axon said and I am not really sure how helpful Hyperthreading really is on a Quad Core.
I'll say it again. X3440
A higher binned processor then the 750 and 860 because it's a Xeon
http://www.newegg.com/Product/Produc...82E16819117225
That is a very good chip. Have you overclocked it? How well can it overclock with a inexpensive HSF like Cooler Master 212? It could be the best choice for Quad core Hyperthreading but it still is $40 more than i5-750. One could easily say i7-860 is only another $40 more but I'm on your side and think this is a excellent bang for the buck cpu(X3440).
Thanks.
SandyBridge is way off in the future, good luck trying to plan a build around it.
SB will be out by the end of this year :biggrin:
Look at the Multi threaded apps. Do you think an 8 second advantage in blender is really caused by a 200mhz advantage? Or how about a 16 second advantage in WinRAR? HT is WORTH IT and anyone who picks up a 750 instead of an X3440 for 40 dollars more is an idiot
http://www.anandtech.com/bench/default.aspx?p=109&p2=108
Thanks for reminding us of the Xeons, seems that most people are unaware of them.
So, the X3440 is the Xeon equivalent of an i5-750, clocked slightly lower stock, but with added hyperthreading? If so, it does sound great. Is this the overall best bang for the buck Xeon 1156? Or does this chip equate more to the i7-860, again at a lower stock clock?
I have to admit I am confused about the Xeon offerings, since they don't appear to be a direct duplicate of the desktop chips.
Yes, I fully realize and agree with you that they are usually superior binning, and usually guaranteed lower VID.
Also, all motherboard manufacturers of 1156 boards don't state compatibility, yet I am guessing that they will all work out of the box? Is there a chance in hell that some app won't know what CPU is being used?
What would be the likely air-cooled range that these would easily get to?
4Ghz on air shouldn't be much of an issue with great air ala a TRUE or Mega shadow. The X3440 is pretty much a lower clocked 860.
X3440 - 19X Multi
860 - 21X Multi
The Xeon will plop into any P55 board and run without issue. EVGA doesn't state Xeon support for my board but many are running it without any issues. My Clarkdale ran on the original september bios shipped with this board so you shouldn't worry about any issues.
You wouldn't then see any reason for the next step up in Xeon's, which is what, the X3450 or greater, just to get a higher multi?
I fully realize that people are using these, just a pinch "queasy" about it.
Where you say that "many are running" (these chips) it is tough to find more than a tiny handful of people posting about them,
or reviews. Of course, being a server chip, consumer reviews are less likely since people just don't generally know about the Xeons at all.
With that lower 19x, wouldn't the integrated memory controller also be a limiter?
About ready to bite and try one.
How do the Xeon overclock ? The Xeon is a server processor and from what I have read about it, it's not a workstation CPU and thus is slower then the desktop line.
These chips are only good for big companies with servers and hundreds of users if not thousands.... It will handle all load easily. thx
