ArchAngel777
Keep in mind that the memory clock speed can overcome the bus width. 128bit is not neccessarly inferior to 256bit. All depends on the memory frequency it is paired with. However, with that said, based on last generation high end parts, it probably will need to be 384bit or 512bit since I don't think were going to seed GDDR5 clock much higher than 4Ghz at this point. It will be interesting... However, the wider the bus width the more expensive the PCB. Additionally, it is possible that memory bandwidth needs do not scale linearly and perhaps we don't need 512bit + 4Ghz memory...
