Magnet strips.
Don't use a wooden block, they can trap moisture and bacteria.
EDIT:
Cutting boards: Glass = bad
Ceramic = bad
nylon/microban/etc = not as bad but unnecessary some people prefer for raw meats
edge glued wood = getting better
end glued wood = best
EDIT #2:
The most important thing is to care for your cutting board properly. I regularly wash mine down with a water and vinegar solution, let that dry then treat with mineral oil.
I've been using my ikea magnetic strip for 6 months now and have no complaints.
I place the dull side of the knife against the magnetic strip so that the knife/strip makes a 180 degree angle, and then slowly lower the sharp edge in place (by "slowly," I mean like 1-2 seconds, just to make sure that no scraping is involved). remove the knife by repeating the operation in reverse.
and it saves me a ton of counter space, which my kitchen is sorely lacking in.
I was gifted a full set of cutco knives about 7 or 8 years ago by a friend of mine who got conned into selling them. When he quit he had a full unused set that he used for demo's or something that he gave me.
I would have never payed for them, but they have held up surprisingly well. They still look new in fact.
Cutco = $20 walmart quality set priced at $300.
If you got them for free then oh well. I used a cheap $20 walmart quality set for 7 years as well when I couldn't afford better. They work as in they cut, but not really that well. A good set is MUCH better to use than anything of that quality.
I thought wooden blocks were good because they will help wick away any moisture left on the blade (obviously you need to dry them thoroughly first, but for that little bit that doesn't come off...). And I don't see how the can trap bacteria if you only put clean knives in them...
Wood is naturally antibacterial which is why it's good for blocks, and cutting boards. I wouldn't use a plastic board for meat, or anything really. Bacteria gets caught in the knife cuts, and doesn't wash out due to accessibility. Where wood would kill the bacteria, it just festers in a plastic board.
For a chef's knife, I have a Henkel 4star Japanese style that I much prefer over the traditional knife with a sharp point. I also have a cheap Chinese chef's knife that I like for some things.
I wasn't completely right, but then neither were you :^PDead and dried wood is absolutely NOT antibacterial, quite the opposite, as moisture is soaked up and held in it will grow without restriction.
That said, a properly washed board of plastic or wood will be just fine and it won't really matter which one you use.
[FONT=Arial,Helvetica,Univers,Zurich BT][SIZE=-1]Although the bacteria that had disappeared from the wood surfaces were found alive inside the wood for some time after application, they evidently do not multiply, and they gradually die. They can be detected only by splitting or gouging the wood or by forcing water completely through from one surface to the other. If a sharp knife is used to cut into the work surfaces after used plastic or wood has been contaminated with bacteria and cleaned manually, more bacteria are recovered from a used plastic surface than from a used wood surface.
been doing a bit more research. anyone have any of these crazy japanese knives, stuff you wouldn't find in these chain stores in the states? I'm looking at knifeforums.com and I'm starting to get overwhelmed. seems like they prefer gyuto style vs. chef. I'm not sure how extreme I wanna go though, and I want to keep my budget at around $120
http://www.woodworking.co.uk/Technical/Bacteria/bacteria.html
[/SIZE][/FONT]
I'd rather use antibacterial soap to just get it out of the surface than having it living in the wood but yeah, with regular manual cleaning they are about the same i suppose.
That said, apart from just cutting vegetables my meat cutting table is wood, i usually just use den ethanol on it and oil it up afterwards.
And yeah, i sometimes need a table to cut meat.
Try a couple. Buy some cheapies in a couple different configurations, then when you find one you like, buy a good one of that design. You can use the rejected cheapies as beater knives. I prefer a straight blade, without a point. You might like something different. You don't need a whole knife set. I do everything with 5 knives...
Japanese style chef knife
Chinese chef knife
4" parer
Ulu
Bread knife
Edit:
forgot the bread knife
I'd suggest using vinegar rather than ethanol. A vinegar solution is plenty acidic enough to kill any food borne pathogens, and isn't poisonous to humans.
I have a Shun 8" and love it. I would recommend Japanese steel over German just because it is typically tempered harder. You can thus get it sharper and it will stay sharp longer as well.
