Originally posted by: Idontcare
Originally posted by: ChampionAtTufshop
Originally posted by: Jeff7181
Maybe building a PC inside a sealed freezer would be more effective =) Just don't open it and let moist air in
like in a vacuum?
Not to be hard on you but that would be the worst possible way to remove heat from your computer.
You've got convection, conduction, and radiation to get heat from one place to another.
You use conduction to get the heat from the transistors in the chip to the fins on your heatsink, and then convection to get the heat from the heatsink to someplace outside your computer box. Put the box in a vacuum and you shut off convection and essentially trap the heat on your chip and heatsink (conduction through your mobo and case will be second if not third order, i.e. negligible).
Your CPU would survive provided the conduction portion were extended beyond the heatsink via water or vapor-phase cooling, but all the other chips on every component in your system would give themselves some heat-death luvving...uh oh!
Oh, and radiation, specifically black body radiation (think of an incandescent light bulb), occurs whether or not the system is in a vacuum, but contributes relatively little to heat transfer at the temperatures we run our chips (<500C).
