Was out running errands today, when all of a sudden my service engine soon light came on, and my car started sputtering.. I could tell immediately. Car has about 65% of the power of normal.
Took it up to autozone, and one of the guys pulled the codes. Just one alarm stating
"misfire on cylinder 5"
cause could be
bad spark plug
dirty fuel injectors
bad vaccuum tube
other mechanical failure
Car is a 2004 bmw z4 with 68,000 miles. haven't changed the spark plugs since I bought it with 21,000 miles. Recently changed the oil.. nothing different, same synthetic oil I have always used (and suggested by the dealer). Oil change about 400 miles ago.
Engine is very rough on idle, very shaky. I've got it parked out in front of my garage.
Guy at autozone said it could just be a dirty fuel injector, maybe from a bad tank of gas. So I bought to GUMOUT fuel system cleaners. Put one bottle in right away. Car has about 30% tank left. I'm going to run it all out till its on empty, put in the other bottle of GUMOUT and about a 1/4 tank of premium. Then run it through again.
Also going for new spark plugs as well. If that doesn't fix it.. i guess it's going up to the dealer. ;(
ideas? advice? it's sitting outside running (idling in park) right now so it will burn through the gas.
cause could be
bad spark plug
bad vaccuum tube
