Just be aware though - the M7NCG has some memory compatibility issues. I couldn't get it to work with GeIL Golden Dragon Value, but it did work with a stick of Buffalo RAM.
Users at Newegg report:
Definitely picky about the RAM. Paired it with 2 PC-3200 256MB sticks of Crucial Value RAM and the system was unstable.
Took out the Crucial and put in some Elixer RAM and it works beautifully.
Great mobo, stable as a rock, good features, even though I could NOT use the onboard video with KingMax PC-3200 ram
Hates some RAM types.
Actually, if you read the other reviews for other NForce AGP with integrated graphics, they ALL have problem #2. We put some PNY 512 PC2700 in initially and the graphics would have problems. NO amount of tweaking with the BIOS settings would help. We replaced this with a pair of Kingston value RAM PC3200 512 sticks (which work at PC2700 speeds too), and it booted right up with no problems. This RAM is using micron chips (crucial's parent company). The stuff in the PNY was some odd (Chinese?) brand chip.
I had an extraordinary amount of system errors putting this thing together until I swapped the Mushkin RAM for the Kingston Value RAM. After that, it worked great.
I did have a lot of frustration though, as the board was incompatible with some Corsair Valueselect RAM (PC3200, CL 2.5) that I had. It would reboot when subject to minor graphics tasks. I'd ignored other users reports for a while, thinking it was a power problem. I exchanged for some Kingston value RAM with similar specs and things are working great now.
Stick with Crucial or Samsung from what I can tell, I tried Kingston, Geil, and PNY, all failed miserably, couldn't even get Windows installed.
I see Kingston Value mentioned a lot as working, though the last user reports otherwise.
Other advice - reduce the frame buffer in BIOS to as low as you can go, which is probably 16MB. She won't even need that much, but at least it'll free up more RAM for the system to use.
Don't forget to equip the PC with Spybot, Ad-Aware, and a good antivirus program.
