Chaser Pills for Hangover- Do they work?
Gibsons
12,530
35
Originally posted by: Fritzo
Originally posted by: Gibsons
Originally posted by: Unheard
There is nothing better for a hangover than drinking a pint of water before going to bed. Hangovers are caused by dehydration.
There's more to hangovers than dehydration. Water does help prevent hangovers though.
No, that's pretty much most of it. Alcohol is replacing water in your bloodstream.
You need to drink 4oz of water between each drink to prevent a hangover. This will usually work. Drinking water before going to bed won't do much.
My post from a previous thread, complete with typos
Hangovers are caused by 2-3 things. Or maybe more...
1 ethyl alchohol - alcohol acts as a depressant and there are perhaps some effects from a 'withdrawal' symptom. it also acts as a diuretic. This results in dehydration, which contributes to the hangover. But it's important to realize that you can be hungover and not dehydrated or dehydrated but not hungover. That is, the symptoms and causes of hangover and dehydration are distinguishable. Alcohol is also processed to an aldehyde and then an acid, both of these might contribute to the symptoms.
2 Congeners - this is the big one. Fermentation by yeast of organic substances (grain, corn, grapes whatever) produces a very very large list of poorly defined chemicals, generically termed "congeners." These lead to headache, photophobia, and lots of other symptoms commonly called hangover. On the plus side, they can taste and smell good...
3 other alcohols - probably not a large contributor, especially these days. will ignore this.
Glycogen metabolism has nothing to do with it. Food stops glycogen metabolism as well as or better than alcohol, but doesn't cause a hangover.
Drinking a lot of fluids during drinking or before you go to bed has two effects. First, it counteracts the dehydration. Second, it gives the kidneys more/better opportunity to process the congeners - they will spend a lot of the night in your bladder instead of washing around your brain.
Aspirin (or ibuprofen etc) helps because it suppresses the formation of prostaglandins. Prostaglandins are probably induced by congeners. If you feel bad simply becuase you're dehydrated, aspirin isn't going to help at all. But aspirin does help hangovers.
Eating food with some water is a great way to avoid a hangover (best that I know of anyway). A lot of the congeners end up passing right through (they get caught up in the food, particularly if it's greasy) instead of reaching the blood stream (and then the brain).
Different alcoholic beverages will give worse hangovers, even given the same amount of alcohol. This is due to different amounts of congeners. Generally speaking, darker beverages will have more, lighter will have less. Highest amounts are found in whiskeys, red wines and beer, lowest amounts in vodka. Obviously there's a lot of variation even within these categories. Some red wines are said to even contain histamines, which is bad to even think about.
Anyway, bottom line is there's a lot more to hangovers than alcohol or dehydration.
djheater
14,637
Originally posted by: DonVito
I always drink a glass of water with every drink - this will pretty much entirely prevent hangovers. In the rare case that I screw that up, I take maximum-strength pseudoephedrine-based cold medicine in the morning - that seems to work really well for a hangover.
I agree it works but I react strongly to pseudo-ephedrine and usually have to lay down for a while after taking it. I get racing heart and free-floating anxiety... :(
bignateyk
11,288
7
Best thing is to drink water while you are drinking alcohol. This is usually impractical, especially while drinking beer. Other than that, drink a few glasses of water, eat some greasy food, and take an advil or two right before going to bed.
uberman
1,942
A valium and a big plate of huevos rancheros. I believe that was in the book, "A Peoples Guide to Mexico," by Karl Franz. The valium helps overcome the effects of withdrawl. The tomato sauce in the huevos rancheros is to settle your stomach. BTW, you don't mix drugs with alcohol.
A Tequila Mary with a big plate of huevos rancheros. The Tequila Mary helps overcome the effects of withdrawl. The tomato sauce in the huevos rancheros is to settle your stomach.
Tequila Mary- Mr. and Mrs T's Bloody Mary mix, tequila, lemon juice, tabasco, ice cubes and salt. Slice up a bell pepper and hang a few slices on the glass. These are fun to chew on while sipping. Some people prefer a stalk of celery.
As always drink water to rehydrate.
SoulAssassin
6,135
To get back to the op's question....I believe they work. I've taken them in past after getting really really tore up and felt 99% fine the next morning.
Dulanic
9,951
570
Every time I drink a lot I take 3 tylenol and a bunch of water... never get a hangover.
uberman
1,942
I don't actually believe I've seen those pills before. Do you have any idea what is in them? Where do you find "chasers?" You have me curious.
uberman
1,942
Please don't do this. Tylenol is a very dangerous drug on its own, but to mix it with alcohol is suicidal. The damage is irreversible
lightpants
2,452
I stand by this:
Alka-Seltzer Morning Relief
I buy it from Amazon.com. It is not available any stores near me. Everyone that I have given it to try said it works. As soon as you wake up, take two tablets dissolved in water and lay down for 1/2 hour and you will feel much better.
:beer::D
Dulanic
9,951
570
Sorry I meant to say Ibuprofen...
uberman
1,942
Originally posted by: BobDaMenkey
You need to pound down more water befor eyou got to sleep amigo :) I've never had an issue with hangovers if I pound down a few good sized glasses of water before turning in even after my most drunken of nights(new years, and when I threw a house party because my parents were in hawaii).
Is it possible that you could housesit for me when I go on vacation?
Mayfriday0529
7,187
Originally posted by: lightpants
I stand by this:
:beer::D
I was looking for Alka-Seltzer at work, didnt find any so i went with seltzer water. Feeling much better now, but not in the mood to go out tonight. Its game 7 though and my buddies won't let me escape. I'll take it easy tonight maybe two drinks only.
SoulAssassin
6,135
My local pharmacy carries them from time to time or you can order from drugstore.com. There's all kinds of funky stuff in them, I tried these other pills that are the same called RU-21 and they were stating that the formula was actually developed by the KGB during the cold war to help spies be able to drink all night and get up in the morning and function.
