LTC8K6
- Mar 10, 2004
- 28,520
- 1,576
- 126
The batteries aren't the problem, the problem is the very high parasitic draw from all the electronics, alarms, keyless entry, push button start (RFID) crap. Disabling the SmartKey system on the Toyotas makes a huge difference in lowering this parasitic draw but you can't do that on the newer cars anymore which totally sucks. On the first gen cars with the smart key system, you could disable the system with a button under the dash but with the newer cars, you can't do this and you basically have to live with this very high parasitic draw which is a problem if you drive your car infrequently.
My Jeep has IOD fuses. If you are going to let it sit, you remove these fuses. This ends most of the parasitic draw.
IOD fuse-Ignition Off Draw.
http://www.wkjeeps.com/wk_fuses.htm#DRAW
http://www.wkjeeps.com/wk_fuses.htm#IPM
