EightySix Four
Originally posted by: IsLNdbOi
So I take a wire then:
- connect one end to the car battery's positive terminal
--- connect the other end of the wire to a 1kOhm resistor
--- then take another wire and connect one end to the other end of the resistor and the other end of this second wire to the capacitor's positive terminal
- Then I take a third wire and connect the battery's ground / negative terminal directly to the capacitor's ground / negative terminal
Did I get that right?
Perfect, I'd have it all mounted up and everything first as well, then all you have to do is remove the resistor and you're good to go.
